Question about Sony Walkman NWZ-B105F MP3 Player
Lost factory settings - sample pictures, videos and music
Was a member of napster received message files were corrupt would need to reformat whichI did following their advice. Settings - commom settings - format.
Wiped everything clean - leaving sony Mp4 empty. Would like to reinstall original information/data.
    President:
  • 688 Answers
You have a disk which came with the MP3 Player.
the disk contains the relevant software.
the device uses windows media player 11
You can follow this link to download a compatibility program for windows vista.
also any drivers necessary to reinstall the software.
Click Here for Software
If you find this post useful please leave a rating. Thanks
Posted on Mar 02, 2009
Tip
How to remove DRM protection from Napster
Napster music contains DRM protection, which always in a DRM protected WMA format. I
f you want to put it into iPod, Zune, or other MP3 player, you have to remove DRM protection from Napster music first. Here is a detailed guide to show you how to remove Napster DRM.
You may need specific Napster DRM Removal Software to strip this DRM copy protection from these Napster WMA tracks. This article presents you a easy way: using software, such as Wondershare Music Converter to remove Napster protection to non-drm ones . This software is especially useful for alleviating compatibility issues.
Here is the step by step tutorial for the program:
1. Download Wondershare Music Converter, install and run it. Then, add DRM WMA music onto it. You can either click 'ADD' button to insert the music you want to convert, or easily drag & drop the files into 'Getting started' table. This software supports batch conversion, so you can add several files at a time.
2 Choose MP3 or WMA as your output audio format. Click the setting button, you can set the parameter with pleasure. You also can change the output file location, or the output files will be located as default.
3.Last thing, click the start button, and the converting process is beginning. After converting, the audio are DRM-ripped. Just finish the process of removing DRM from Napster WMA in several minutes.
Please click here to read more about this artcle
If you would like to see the demo about the details guide ,please
kindly check here :http://www.youtube.com/watch?v=IdxSWfjWe90
on Dec 30, 2009 | Computers & Internet
My nokia 6300 keeps saying memery full unable to receive messages ive deleted all i can
You will have to restore the factory settings of Your phone to be able to stop this problem. Since deleting all the messages did not solve the problem. First of all, be sure that the message you are trying to receive is not a multimedia message, like pictures, music/songs and videos, because those files require a larger space to be able to receive such messages.
To restore The factory settings of Your phone,
  1. Properly charge Your phone,
  2. Go to the menu,
  3. Select the settings,
  4. In the settings, scroll to restore factory settings,
  5. It sometimes prompts You for the phones security code,
  6. Enter the security code of the phone,
  7. A page will come on showing a loading page, once it has completed its loading,
  8. The phone will be restored to the way it was when You first bought the phone.
Hope this was helpful. Thank You for using FixYa!!!
Hope this information helped You. Thank You for using FixYa!!!
Jan 12, 2011 | Nokia 6300 Cellular Phone
Same problem different twist
once the files are corrupted you are stuck with a reformat as a solution, have dealt with this many times.
Sep 04, 2009 | Naxa Electronics Naxa Stereo AM/FM.MPX...
Reformat MotoRazr V3xx
update the firmware on your phone
Dec 28, 2008 | Motorola Mobility RAZR V3
Lost pictures on LG Voyager
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% safe
Dec 01, 2008 | LG VOYAGER VX10000 Cellular Phone
My sansa E250 has been corrupted!!
My MP3 freezes up when I turn it on
How can I fix this problem?
Aug 03, 2008 | SanDisk Sansa e250 MP3 Player
Toshiba Gbeat F10 "files not found" Napster says to reformat
I had this problem on mine as well. The problem was that the liscenses on the music was expired. I had to remove the music and then reload it and have had no problems since. Good luck.
Sep 22, 2007 | Toshiba Gigabeat MEG-F20S MP3 Player
Transferring Music from Napster w/o WMP
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downl...
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Sep 01, 2007 | SanDisk Sansa E280 MP3 Player
DRM Software Corruption
Nice. That worked great.
Thanks for posting.
Jul 09, 2006 | Rio CE2100 MP3 Player
Sony Walkman NWZ-B105F MP3 Player Logo
124 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
