Question about Samsung YP-K3 MP3 Player
So Sad It Wont Turn On
K well it was a yucky day outside and i droped my mp3 on the ground just before i opened my door and now it flickered when i try to turn it on and now it dosent even flicker and there is no reset butten...I Have No Idea What I Should Do....?????
  • 3 Answers
According the manual, the reset hole is on the rear near the bottom.
Manual is available here:
http://www.samsung.com/ae/support/download/supportDownDetail.do?group=audiovideo&type=mp3players&subtype=flashmemory&model_nm=YP-K3ZB&disp_nm=YP-K3&language=&cate_type=all&mType=UM&dType=D&vType=&cttID=1335472&prd_ia_cd=03040200&model_cd=&menu=download&menu2=detail
Look at page 8.
Posted on Mar 07, 2009
No power to car key wont turn
check the alternator and check for a short or ground a wire may be touching the frame you may want to check the engine computer module
Feb 17, 2014 | 2004 Mercedes-Benz S 430
Drive door won't open from outside on 95 ford thunderbird
if your door is unlocked and it wont open from outside the handle to door latch rod has come undone sometimes the clips holding on handle become brittle or some models the rod uses gravity to sit in the latch and can be jarred out.
take door pad off and its all self explainatory or go to body shop they do these 20 times a day and usally wont charge much
Jan 28, 2014 | Cars & Trucks
My passenger side door stoped opening from the outside. For one day i had to always open the door for passengers from my drivers seat. Now the inside wont open the door either. The outside handle is...
{: ) The passenger door trim panel should be removed, and the inside inspected carefully for any binding of linkages, stuck up levers or cables, or worn out grommets, broken pieces, before deciding for a doorlatch replacement.
Jun 03, 2011 | 2006 Chevrolet Trailblazer
1006 sable wont start itran fine 1 day then the weather droped to 10 that night .the next day it would not start it just pops
Sounds to me that water is present in the fuel system. Another would be a defective coolant sensor, and air temp sensor, these detect outside temp and render this output with the ECM.
Apr 04, 2011 | 1996 Mercury Sable
How do u fix a mp3 player that dropped on the ground and in water
Try to take the battery out and then, dry the poles of the battery and the mp3 player, then leave it in a dry place over night and try again.
Hope this help :O)
Jul 05, 2010 | Philips GOGEAR SA6045 MP3 Player
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
My ps2 wont turn on
Droped it , now your screwed
Nov 15, 2008 | Sony PlayStation 2 (PS2) Console
How to put battery on insignia mp3
there is a small 3 prong clip that goes into the mainboard on the back
Oct 27, 2008 | Insignia Pilot MP3 Player
MP3 player won't turn on
mine usually turns on the next day
Aug 16, 2008 | RCA OPAL M4001 MP3 Player
My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Mar 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Samsung YP-K3 MP3 Player Logo
54 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
