Question about HP LaserJet P2015 Printer
Laserjet P2015 with Windows Vista
I have problems to setup printer running under Vista 32bit.
First problem: After plugging in the USB cable into the computer, i going to be installed (I downloaded the PCL6 driver for Vista from the HP website). but not install
thies link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1845551&prodNameId=1845552&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=hv-43324-2
what can i do
    Novelist:
  • 102 Answers
Posted on Jul 03, 2009
How to install Printer HP LaserJet P2015
Installation procedure comes along withe the printer.. read carefully and do your self..
> Printer hard ware setup, like unpacking, cartridge loading, loading the paper,connecting the power...
> Don't connect the printer to CPU..
> Run the driver CD
> While searching for device plug the USB cable in the printer & switch it on
> Do the rest of the installation.
> Finish it up check the test page...
Oct 05, 2011 | HP LaserJet P2015 Printer
I have a printer hp laser jet p2015 and laptop with vista the windows can not recognized the device what i can doo
From the manufacturer's web-site: http://support.hp.com
enter 'P2015' and do a search.
Select your model of printer.
Select Windows Vista.
Select the device-driver, download it, and install it.
Sep 28, 2010 | HP LaserJet P2015 Printer
I have a laptop with windows7 so i cant install HP LaserJet P2015 printer ... When I run the setup from the installation CD, I get an error that says, ....
Mmm. Well, once I was unable to install a HP LaserJet P2050 on a laptop. The cause is most probably that it runs Windows Vista, and that the CD isn't compatible with Vista, so I think you're problem is the same. Hope that helps,
Daniel
Jun 18, 2010 | HP LaserJet P2015d Printer
Plug and play problme :(
Unplug the printer, run the software again to set it up, wait until it tells you to put the USB cable into the printer and then do it, not before...and so that it doesn't carry over from the first install put it in a different USB port the second time.
When infected with the Vista virus it's all about doing things in exactly the right order for them to work.
Oct 02, 2009 | HP LaserJet M1120 MFP All-In-One Printer
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
Installation
get the latest HP driver by clicking on the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1845552&prodTypeId=18972&prodSeriesId=1845551&swLang=8&taskId=135&swEnvOID=2093
run the installer and follow the steps
your printer will be installed
Another way to accomplish this could be,
going to printers in the control panel after connecting the usb cable o the computer and running the add printer wizard there.
Jun 14, 2009 | HP LaserJet P2015 Printer
Cannot install HP Laserjet P2015 on my vista 32bit pc
Try going to www.hp.com click on "drivers and software" enter your printer model number and download the software from there.
May 18, 2009 | HP LaserJet P2015 Printer
Cannot install hp2015 usb printer in windows 98
Make sure you the full install program/download. We're going to back pedal and try it again.
First:
  • Disconnect the Printer cable.
  • Click Start
  • Click Control Panel
  • Click Printers
  • If your printer shows up here, remove it
Then:
  • Run the Install program again
  • Only plug in the cable when prompted to do so
When you plug the cable in it should now recognize the printer.
Best regards,
Mike
Apr 15, 2009 | HP LaserJet P2015 Printer
HP LaserJet P2015 Printer Logo
211 people viewed this question
Ben Johnson
