I have a Sony KP-51HW40 projection TV and it is about 7 years old. It started have some bright yellow, almost neon yellow lines zap through it intermittently. It affects the picture for about a second and goes back to normal. Is this too expensive to get fixed?
  • 1 more comment
  • hansentoolco Mar 02, 2009
    what is "convergence"? Where would I find the part number to get this fixed? More answers needed please.
    Thanks so much.
  • hansentoolco Dec 03, 2010
    You replied to me a couple of years ago about my tv problem. I am wondering how lyou suggest that I can fix this "heat sensitive board".
    Novelist:
    Scholar:
  • 95 Answers
This type of problem can be common. The Circuit board or where the components with age and heat can become lose so tapping on the side of the TV might bring it back to confirm you have this problem.
If you are a do it yourself er, you can open the back, (do not touch any of the caps with long wires going to each TV, they carry very high voltage and will jump 1/2 inch and sting you but not kill you..
With the set on, and a NON metallic piece of plastic you can gently press in the middle and outsides of each of the circuit boards and maybe see the problem come and go. Use a mirror to see the TV screen in the front so you can work from the back.
Never do this alone in case of shock.
I highly recommend you find a company that does repairs that is good with intermittent connections and can flip the bad board over and re soldier the cold or lose connectionIf you get a good picture and you like it then your 3 (electronics term). This an old school solution as the replacement board if available can cost hundreds of dollars plus the service fee.
Call around your local area and find a company that has an older repair guy with experience that says they know how to fix it in house. It might take from 1-3 hrs to fix if they can consistently make it go bad by flexing the suspect board.
Good Luck!
e
Posted on Mar 02, 2009
  • Eric  Kirkhuff
    Eric Kirkhuff Mar 03, 2009
    You have been getting some sound advice. If I am understanding that the picture comes clear then intermittently has lines in it not full screen change in color which would point to the one of the three TV tubes.
    This sounds like the cathode tubes or TV tubes are ok and it is a heat sensitive board part or cold connection.
    Novelist:
  • 121 Answers
It really depends on what you consider expensive. Looking at this Sony site, parts are under 300.00, but then you have to look at service rates. Normal hourly repair rates are around 70.00 to 80.00 an hour. What you are experiencing is the Projection Lamps (Bulb & Housing) dieing. This is common in Projection TV's and are some what easy to replace if you opened up the TV and located the part. The part costs $212.95 on the site I posted above.
Armymason
    Scholar:
  • 165 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
click this link this link will guide you from how to do and with proper procedues and diagrams.  its not very costly issue but if you do not have technical knowledge then repair person is necessary at your place to do this as its worth getting it repaired . a common problem which gets repaired mostly without much heavy cost. thanks. please do rate the solution.
    Brigadier General:
  • 8,619 Answers
Hi!
Try checking the tv with a dvd player or try using other cables such as hdmi and see if the yellow lines disappear.
    Sergeant:
  • 239 Answers
Sounds like your cathode tubes are going out.
these are the tubes that provide power to your tv projection bulbs. there are three of them and the cost about 350 dollars each. plus about 400 for some one to fix. it would be cheaper and easier for you to replace the tv.
hope this helped.
please remember to rate me.
  • 10,594 Answers
If it is one of three picture tube problem then it may cost you much and if it is some dry soldering in picture tube boards and video drive circuit then it is not costly, may be $100 plus.
    Sergeant:
    Novelist:
  • 277 Answers
No its not expensive to get fixed near to $ 30 to get it fixed with parts.its the convergence problem get it fixed.
Before going to Florida, I used my playstation on my KP-51hw40, and had an amazing picture. I took my playstation out of town and used an old TV to play. When i came back into town and hooked it up to my...
it sounds like the playstation is still set for 480i. do you have it hooked up composite? (one yellow vid cable) that could be your problem, ps3 optimal with component(red green blue vid wires) or HDMI, then make sure your settings are saving properly on your unit
Mar 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Need repair manual for Sony KP-51HW40 television
Try this link. It helped me fix my sony. www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 04, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp-51hw40 with yellow spots over 50% of screen
probably contamination in the picture tubes is a lengthy job to change the fluid in all three tubes is also costly. probably as well off to purchase new set.
Aug 07, 2009 | Sony KP-51HW40 51" Rear Projection...
SONY PROJECTION TV (42 inch)
most sure your tv is getting sick, just kidding
probably convergence problem you may need to call a tv tech
Aug 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Lines on my screen
Try this link it has many great reviews. Very informative for the DIY. The description of your problem was very vague. If this helps great.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Dec 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40
I had the same problem with mine 2 years ago (TV was 1.5 years old at that time) I had extended warranty on TV and it was fixed by Sony at no cost to me. Now yesterday I have another problem with it. All of a sudden screen went BLUE. No Sound either. It could be the CRT (That's what I read here) Out of luck this time. Will call local Repair shop (70 miles away) and see how much it will cost to fix it. Good luck.
May 31, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
