Question about Seagate Barracuda 7200.10 ST3160815A - 160GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6) - ... 160 GB EIDE Hard Drive
Seagate satat error
I have an amd athlon 64x2 dual core processor 2.4ghz and 1gb ram.. equipped with 160 gb seagate sata hdd.. everythign was fien until 27th feb 09 when winxp hanged and showed up the blue death screen. i tried reinstalling xp by a cd but the xp installtion can't format the hard drive.. like, when i enter the option FORMAT USING NTFS function, it doesnt even show 1 percent.. but when i format it using FORMAT USING NTFS QUICK, it formats and installs xp in a jiffy... im confused if im really able to rectify this problem or else give it to the nearest seagate for a check up..
help at the earliest would be highly appreciated
  • mcshyam Mar 04, 2009
    thank u for ur reply sir.. yes i did a quick format and it took just abt 45 min to install the whole xp sp2.. but the real thing is that im not sure now if there are actually bad sectors or not :( even after starting xp, i tried formatting the remaining partitions using NTFS(disk managment window) but it hanged while 11%.. later when i tried a quick NTFS format it formatted successfully and it is running smoothly just as new..
    so by doing a quick format and installing xp, will xp crash in the future?
    plz help!!!
  • Damon Gray
    Damon Gray May 11, 2010
    If the drive formats and you can install with Quick Format, does that not solve the problem? The quick format simply erases all the file location data (as though there were no files there) but actually leaves the files in place and allows the data to be overwritten. The "long" format actually erases all the data on the drive. With a 160 gigabyte drive, this can take a good while to accomplish. How long did you allow it to go?
  • 29 Answers
The firmware is damaged,sir,nothing can do.you should go to the dr company to repair your hdd first by using HD Doctor or other tools,it is a typical bug for 7200.11,seagate's big bug
Posted on May 05, 2009
If i change my processor can i put more ram in than my comp calls for as max
No. The motherboards stipulates what can be added or changed.
Aug 31, 2012 | Computers & Internet
Upgrade processor in Toshiba Satellite AMD Athlon 64x2
Best way to do all that is to buy a new computer, already configured as desired.
Oct 13, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Want to get more ram for my computer
Use the free tool on this site to scan your PC to determine what kind of memory you need:
http://www.crucial.com/index.aspx
Mar 16, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Two problems:1) Audio2) Freezing when running AMD Overdrive
format your hdd fat32 with xp geneuin. then setup motherboard driver...
Jan 08, 2008 | Gigabyte GA-K8N51GMF Motherboard
Seagate Barracuda 7200.10 ST3160815A - 160GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6) - ... 160 GB EIDE Hard Drive Logo
226 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
