Question about Zanussi 18 in. DA4342 Free-standing Dishwasher
Hi there I have a Zanussi zdf121 dishwasher which is only doing a cold wash, not heating at all. Not sure if its hot fill but the hot water is fine elsewhere. Any ideas please Pete
  • 224 Answers
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
Posted on Jul 04, 2009
The dish washer washes ok, but often does not dry the dishes. I have descaled and cleaned it but still hit and miss. can i fix it my self. thank you Chris
You didn't state the precise model, but if it's a cold-fill only machine (most Zanussi models are) and if it uses condensation drying like most, then a cold water supply is essential for the latter to work.
Many owners connect such machines to the hot supply in the mistaken belief that it will make the machine cheaper to run, but unless they have free hot water (solar heating?) then it's usually a falsehood and the trade-off is incomplete or non-existent drying.
Jul 16, 2011 | Zanussi Dishwashers
Washes but water does not heat up and dishes cold
The dishwasher does not heat up the water. The water should be hot coming into the dishwasher, check your hot water supply source, whether it be the hot water tank or be sure the water inlet for the dishwasher is not connected to the cold water line
Jan 09, 2011 | Zanussi Dishwashers
Keeps on heating and no cool rinse put in new thermostat still heats and heats zanussi fle1416w
Sounds like you have it connected to hot water supply. This is a cold water fill only machine.
Jul 30, 2010 | Zanussi FLE1416W Front Load Washer
How do i reset the dishwasher when light is flshing but not run
Hi
To reset the Dishwasher when the light is flashing press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water your incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this insures your unit fills with hot water and not cold.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
Jan 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Zanussi dishwasher water input
it is possible but if you use a hot fill you will find that the rinse aid will produce a large amount of foam and the dishes wont dry properly
Dec 22, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Problems! zanussi zsf6120
You can check the heating element with an ohmmeter and it should read a few hundred ohms. Don't know about the thermostat but it should be inline electrically with the heating element and should ohm as a short when cold.
Nov 23, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Water not hot
Dishwashers are suppose to be hooked up to hot water. If you had hotter water it would clean just fine. 120 deg or more!
Nov 01, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Zanussi 18 in. DA4342 Free-standing Dishwasher Logo
264 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
