Question about NEC MobilePro 790 Pocket PC
Critical error 678 on mobilepro 790
When i plug my mobilepro into the com port, i receive a critical error 678. I downloaded the activesync, and it does not recognize the connection, HOWEVER, when i DO click on the connection, the mobilpro 790 responds, then gives me the critical error. Clearly, its connected on some level since it knows what i am doing to the PC, but i cant get it to speak to each other nicely!
help!
thanks
lara
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Error code is 678 means Ur com port not correct configure so before u connect anything u must to configure correct.
Posted on Mar 29, 2010
Device not detected
If you are having problems with all usb devices, then you'll probably find that your usb ports aren't configured properly. This means that there probably isn't a problem with the Mobilepro.
Using windows update, (you really need this to be set to search/download all microsoft products), download all available updates using the custom search. With laptops, not all drivers/updates will be available, as they would have been modified slightly by the laptop manufacturer. So you also need to download the most current chipset drivers from your laptop manufacturer's website. This should sort the problem.
Dec 05, 2008 | Computers & Internet
Syncing my MobilePro 790 with my computer
yes...quite an issue, eh? what is the actual model and make of that device?
Mar 20, 2008 | NEC MobilePro 790 Pocket PC
Error 678
What version of ActiveSync do you have on your computer?
I assume that you have had this device for a while and are not new to it. I am currently using version 4.2 of ActiveSync, which you can download from Microsoft, and rarely have any problems with it.
I would try doing a soft-reset on this machine, restarting your desktop computer. I would recommend uninstalling ActiveSync if you have an older version and installing 4.2, or even 4.5, they both seem to work well for me, and I rarely have problems. If this doesn't work, you can always do a hard reset on your 900, which is removing both batteries, waiting no less than 15 minutes with both batteries off, and then re-inserting the batteries and starting over. (Do this only if you have nothing you would regret losing, or if you have backed-up your data.)
I mentioned the hard-reset because it can often save you a lot of hassle of looking all over for the answer and then finding out that the answer you got gets you nowhere.
If you are able to, I would do a hard reset plus uninstall older version of ActiveSync and install either version 4.2 or 4.5 on your Windows XP or earlier machine, and then see if that works.
If that does not work, go to http://www.hpcfactor.com/forum, go to the section for Handheld PC's, and make a post with your problem and someone will answer. They are really good with these machines and can usually point you in the right direction.
Hope this helps
Regards,
elMono28
Aug 26, 2008 | NEC MobilePro 900 Handheld
Nec MobilePro 790 Handheld pc.
I don't believe that I've seen that..how did you 'send' that information?
Mar 22, 2008 | NEC MobilePro 790 Pocket PC
Critical error 678
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpia2302
http://support.microsoft.com/default.aspx?scid=289706
1) make sure you have the latest active sync installed
C:\Program Files\Microsoft ActiveSync\drivers
or
c:\windows\system32\drivers....with activesync 3.7 anyways.
2) go to contro panel -> system -> device manager -> view device b
connection -> plug and play bios -> pci bus -> usb host controller -usb root hub
3)delete everything uner usb root hub.
4)from control panel run add new hardware
5)now everything under your computer's usb hub including the cradl
will be installed properly.
6)once this installation is performed, you will make sure to see "H
USB Sync 1620" under USB root hub
Jan 17, 2008 | NEC MobilePro 900 Handheld
Device not detected
download the usb drivers
Jul 29, 2007 | NEC MobilePro 900c Pocket PC
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800:ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
Sep 15, 2005 | NEC MobilePro 800
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800: ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
Sep 15, 2005 | NEC MobilePro 770
Service Pack 1
NEC Computers has developed a service pack to address several service issues with MobilePro 780 and 880 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 780 and 880 systems immediately by installing this service pack according to the installation instructions. * Download Service Pack One for MobilePro 780 and 880: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Installation * See Contents of Service Pack: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#FAQ Installation Instructions for Service Pack One for MobilePro 780 and 880 First download the service pack (MP78_UPDATE.CAB) to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP78_UPDATE.CAB file, follow these steps: 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Full (hard) reset on your MobilePro. Caution: Performing a Full reset erases all your data. Your MobilePro resets to the factory default settings. Please perform the backup first or you will lose data! 3. Copy the MP78_UPDATE.CAB file to you MobilePro desktop. 4. Install the service pack by double tapping the MP78_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. The following Message box will be displayed: Warning !!! 1. In order to ensure these patches are properly installed you must perform a Hard Reset prior to the installation. 2. You must back up all application and data files before performing a Hard Reset. The Hard Reset WILL ERASE all applications and data stored on this Mobile Device. 3. This file must be installed immediately after performing a Hard Reset on the Mobile Device (before any applications are reinstalled). 4. Press CANCEL to exit. Or Press CONTINUE to install this file. 6. Press Continue to install the service pack or Cancel to back up your data. 7. When the Setup Finish message box is displayed, Click Ok. This will remove all temporary files from your systems. 8. When the Setup Complete message box is displayed, click Ok. 9. Perform a Soft reset on your MobilePro. 10. Optionally, restore your MobilePro data using the ActiveSync restore procedure. 11. Once the service pack is installed, NECC recommends that you use the ActiveSync b
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Service Pack
Sep 14, 2005 | NEC MobilePro 880
NEC MobilePro 790 Pocket PC Logo
198 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
