Question about Sony BRAVIA KDL-46W3000 Television
Sony KDL40Z4100 Screen Setup does not default to 4:3 signals
I have a new Sony KDL-40Z4100 with AT&T Uverse TV on the HDMI 1 input. How do I program Wide Mode, Auto Wide and 4:3 Default so that the TV automatically displays 4:3 and 16:9 pictures without distortion?
With Wide Mode set to Wide Zoom, Auto Wide set On and 4:3 Default set to Normal; a 4:3 signal always displays streched (distorted) accross the whole screen. Manually changing to Normal will display the 4:3 signal correctly with black bars on each side and the picture the full height of the screen
Changing to an HD channel with a 16:9 picture will then display small in the center of the screen with black on all four sides until I change the setting again to Wide Zoom or Zoom.
I know that it is possible to have the TV automatically displays signals in the correct aspect ratio because our 6 week old Samsung LN37A550 does so flawlessly!
3 Suggested Answers
  • 5 Answers
SOURCE: Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
Posted on May 25, 2009
dave1645
  • 834 Answers
SOURCE: HD broadcast picture is not full screen. How do I
go into your customers setting and change you aspect setting to either full or auto
Posted on Sep 17, 2009
No signal in all 4 hdmi ports on th new samsung 6050. Tried running from Sony receiver and then direct format uverse cable box. Still no signal. It is as if there is a compatibility problem. Help!
I would try connecting a dvd player to one of the HDMI input on the tv to be sure the tv is the problem.Try new HDMI cable 1.3 version. ATT uverse boxes are alway a source of problems and I would assume it was bad before I would condem the tv. If the tv is bad and it is under warranty an authorized servicer will replsce the main board.
Jun 08, 2011 | Samsung Televison & Video
Hello My, just bought Sony KDL 46 NX 700 shows on the screen " No signal. Check the external input or select another input using the input button". My TV cable is connected and TV it replaced...
I have one of these. It is probably set up for some other program like the HDMI or Input 1 through 5.
You can press your INPUT button, then scroll to the TV function, which should show up on the top.
Jan 09, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Just brought a new Sharp Aquos LC-40LE810UN. Every time I turn on the TV, using either HDMI or component cables, the input screen ALWAYS cycles between 480p and 1080i trying to find a "signal"...
This tv the tv Tuner signal board have intermittent interlacing scanning freqencies problem.Tv is new,u just bought this tv wright,return it get another one for the replacement.
Dec 11, 2010 | Sharp Televison & Video
Just set up the tv... have cable going to hdmi 1 and dvd to hdmi 2... checked all wires, but tv saying NO SIGNAL... wondering what am missing. is there a setting i have turn on for hdmi input
On your Sony TV remote, press the "Input" button and make sure you select HDMI 1. Also, check to make sure you HDMI is plugged into your cable box.
Feb 14, 2010 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
My sony kdl40z4100 will not turn on. It worked normally yesterday. I checked power cord, surge protector, as well as the cable box. The remote works, but the TV will not power up.
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 29, 2009 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Technical Details
  • Brand Name: Sony
  • Depth: 2.8 inches
  • Refresh Rate: 120
Technical Details
  • Brand Name: Sony
  • Depth: 4.3 inches
  • Refresh Rate: 120
May 25, 2009 | Sony Bravia Z KDL40Z4100 TV
Sony BRAVIA KDL-46W3000 Television Logo
134 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
