Hi Carole. You can easily download a copy of the user guide by clicking on the following link, then entering your model number in the box.
SOURCE: I require instructions on how to use the Bissell Powerwash
Contact the Bissell services in your country - most of the Bissell sites (www.bissell.com) for example have Adobe user instructions of which you can download.
SOURCE: bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
SOURCE: bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
SOURCE: how to operate bissell carpet cleaner.
Look at the Bissell web site. You can enter the model number and get the operator's manual for Bissell products.
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you
need and a manual you can view:
Bissell 7901 Belt and Manual
Testimonial: "just what I was looking for thank you"
