Question about HP Office Equipment & Supplies
USB WIRE DOES NOT HAVE GOOD CONTACT IN PRINTER PORT
We have to push very hard and cannot keep contact with the wire at the printer port for the wire. wire works good on other products. Just got 4240 printer for x-mas from son. how can we get this corrected. Other printer and copier works OK if we can keep the computor connected.
  • 173 Answers
Buy USB PORT and place all your usb wire
Posted on Mar 02, 2009
Incorrect port
may be your printer usb port's base loose.contact any good soldering expertise and solder the dry joint of your printer's usb base.your problem will solved
Aug 29, 2012 | Canon LASER SHOT LBP-2900 Printer
Just installed a 1200 all in one HP printer and it goes through the motions of printing but nothing is on the paper, i have deleted, reinstalled, check every setting possible, done everything that the...
Many a times the cartridges get empty.There is ink in the cartridges,this ink gets over or many a times dried up.Remove the cartridges and see.There will be a steel color nozzle at the base of cartridge,from where the ink comes out.Touch the tissue paper to that base and see,if there is ink coming out.Actually the ink should come out.There will be two cartridges in the printer.One black and one tri-color.On black cartridge when you touch the tissue paper you will get black ink on tissue.On tri-color cartridge when you touch tissue on its base you will get three colors,that are yellow--- blue and pink.( In printer language its called cyan--- yellow---magenta color).If there is ink in the cartridge then it should print,If you have replace the cartridge,then on its base there is a blue color tape.That tape has to be removed from its base.If the tape is not removed the cartridge will not print.-------- One more thing.Before doing any thing.Just do a self test and see if the cartridges are working. The procedure of self test is as follows:--- " 1) Turn the printer on.2) The power on green light should be steady green,not blinking green. 3) When its steady green at that time.Press the cancel and color button both together. 4) By doing this the green light will flash,and printer will take the paper. 5) On that paper the self test will get printed.But if the printer takes the paper and it comes out empty /blank then its cartridge fault.But if the self test is getting printed,then yes its confirmed that there is communication fault between printer and computer.In this case,replace the usb wire.Try new brand usb wire and see if that is helping.One more thing.When you install the printer driver.At that time never keep the usb wire connected between printer and computer.Only keep one side of usb connected to computer tower.In between the installation procedure.The message will come up on your computer screen" this message reads,connect the usb wire to printer.At that time connect the usb wire".As you connect the usb wire the message will come up on your computer screen.The printer is detected.If this message comes up then only your printer will work.If this message does not comes then,there is any of the three things faulty,that is usb wire,the usb port on printer side or usb port on computer side.If usb wire is faulty you can replace this wire with new and check.Its not a costly wire.But if any of the ports are faulty,then this ports are internally soldered on the main board.This ports needs to be re-soldered.This can be done by any printer/computer repair tech.Its hardly a 10 minute job to re-solder loose usb port. ------------- Try this troubleshooting procedure.This will help. Thanks.Helpmech.
Jan 27, 2011 | HP PSC 1210v All-In-One InkJet Printer
When I try to print I keep getting a message that says the printer is busy or is offline....neither is true....any suggestions?
wat is the name of the printer next time plz mention operating system adn printer name connectivity like if it is wireless or hard wired
Dec 15, 2009 | OKI C5500n Laser Printer
My computer keeps saying it cant find my 4GB
Does the device work in *ANY* USB port on your computer?
Do other USB devices (mouse, keyboard, printer) work in the USB port that you are trying to use?
Does the device work in any *OTHER* computer (laptop/desktop) ?
Sep 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Lost cd for laserjet 1320 cl6 printer. installed
either the usb wire is getting loose in the new laptop port.or the port is faulty.press the usb wire tightly and then try printing keeping it pressed at the laptop side and printer side too.with some bodies help. check out.
Jul 12, 2009 | HP LaserJet 1320 Printer
WheneveraI try to install my cx8400 when they ask
Then your USB cable is bad or the USB port is not installed properly or the port is bad (or very slightly possible the printer is bad). Narrow it down by trying a different cable, a different port, test the usb port with another device, try the printer on another computer.
Jul 06, 2009 | Epson CX8400 All-In-One InkJet Printer
What can I use the 2 USB ports on the stand for?
This is a simple HUB that has two type A receptacles and one type B receptacle; you use a printer style plug to connect the Type B receptacle into an available USB port on your computer. Then one port becomes two. It's not a powered hub from what I can see (the ports are on the base, which isn't wired to the monitor, so no power), so that rules out most external hard drives. I don't know of any monitors that use USB for anything, but printers, flash drives, cameras, and the standard small gadgets should work fine on it.
Mar 17, 2009 | LG L1910B (Silver) 19" LCD Monitor
External hard drive problem
The problem is that the printer, being a composite device, takes a lot of energy from the computer USB ports. Some computers, such as some Dell computers, have problems with USB ports due to a cheap manufacturing. What I can suggest you is to simply unplug the printer when you want to use the HDD, because no matter what you do, you'll have the same problem and that's because of the computer that won't supply enough power to the USB ports.
Also, if you are using a laptop, remember to keep it plugged to the power so it can provide more energy to the USB ports.
Aug 06, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Problems using usb ports
I assume these are the built in ports you are
having trouble with.Do you have a terminal to
install another usb port via a dongle It may be
that the inner terminals of the usb receptacle
are not making good contact (defective) If you
have a junk board with same setup you
might be able to desolder the port,and
replace yours. I haven't had the occassion to
try this yet, but it might work
Nov 16, 2007 | AOpen AX4SPE Max (91.8AT10.501)...
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
