Question about Kodak EasyShare One Digital Camera
Memory card problem
When my son goes to try and take a picture, it says memory card needs to be formatted, do you want to format? He presses continue (meaning yes) and then it says can't read memory card?! he got the camera for Xmas and has taken pics and/or movies before this occassion?? Please advise. Thanks
  • 423 Answers
Hi and welcome to FixYa.
I'm not sure about your particular instance, but this can happen if you change up cameras or use a card reader.
As for being unable read the memory card, sometimes the card can be switched off by accident. Turn off the camera and remove the card. Look at the side of the card and there will be a little switch. One end says locked (or shows a little picture of a locked lock) and the other end says unlocked (or, shows a little picture of an unlocked lock). Just move the switch to unlocked.
Try that, and let me know with a comment if that doesn't work, othewise, thanks for coming to FixYa!
Rob
Posted on Mar 02, 2009
  • 4,806 Answers
Hi there
The card may still be in write protect mode, take the card out and unlock it, it will be at the side of the card like this memory card problem - 59a6de4.jpg .
Put it back into the camera and try to format it again, if it still does the same thing the card itself maybe damaged.
Good luck and thanks for using Fixya!!
Memory card requires formatting, press continue then it states that it will delete everything on memory card,then it does not format, it tells you that you need to format memory card. press cancel and...
Hope you have this figure out if not here goes. Sounds as if the camera is caught in a feed back loop. As long as you have down loaded and saved your images on the computer go ahead and format the card. When it says delete everything on the card select OK and click the start button everyone is happy again. By the way all new card and card after doenloading to the computer should be formatted in the camera. Never format in the computer and deleting images one by one is just a great way to totally mess up a memory card's mind. Format, Format
Dec 09, 2010 | Kodak EasyShare Z7590 Digital Camera
Memory card needs formatted is displayed on the screen. Deleted the pictures and it still comes up. Tried to take more pictures and the memory card would not hold. Is there something wrong with the camera...
I assume you have an SD card. If it's bigger than 2GB then it's actually an SDHC card and will not work in the ZD710.
No, there doesn't seem to be anything wrong. The card just needs to be formatted. In any mode press the Menu button. Press right-arrow to select the Setup tab (camera and wrench) then press OK. Press up/down-arrow to select "Format" then press OK.
Make sure you format the memory card. It's okay to format the internal memory, of course, but your current problem appears to be that the card needs to be formatted.
May 28, 2010 | Kodak ZD710 Digital Camera
Will not format Memory Card for Use.
Hello my friend.
Try this tool which you can download clicking here.
It can solve your formatting problem.
- Download the file.
- Plug your memory card into your PC.
- Run the "exe" file that you downloaded.
- On the program menu select your device (memory card).
- Select FAT32 as file system.
- You may give a valid volume label.
- Uncheck the "Quick Format" option.
- Then start formatting your memory card clicking the start button.
This formatting will delete all the files in your memory card.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 28, 2010 | Kodak EasyShare Z740 Digital Camera
Put new memory card in camera but has formatting problem. When memory card is put in it says the new memory card requires formatting. When I continue it states that formatting will delete everything in...
New batteries first!! Make sure they are "GOOD"
May have a bad or incompatible card.
Will you camera take pictures without a card in it?
If yes, you have a bad or incompatible card.
Try another card
Here is all the information you'll need to solve this:
Read it.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=8814&product=EKN031714
Dec 24, 2009 | Kodak EasyShare Z612 Digital Camera
How did my pictures get deleted by formatting the card?
when you format something it deletes everything leaving it how it came from the factory, it's possible that you had corrupted files and the camera advised to format, next time cancel
Aug 04, 2009 | Sanyo VPC-E760 Digital Camera
When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Regards
Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
Camera/computer say memory card "needs to be formatted".....
i would save your pictures on to a disc, then re-format the card.
Jan 25, 2009 | Digital Blue EasyShare MD1063 Digital...
My Kodak EasyShare C315 needs formatting.
For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
Tami
Dec 27, 2008 | Holga Flash, 120 Medium Format Camera...
W700 i
Try installing the latest firmware and see how it goes..........
It may also be the virus, so also try to format your memory card, but have the contents copied and try that formatted memory card with your mobile......
To format it,
turn off ur phone,
then press and hold the pencil/ABC key then turn the unit on....
continue to press ABC until it completely boots up, now ur in safe mode....
from there, try to format ur memory card then ur phone itself....
*#7370# to format ur phone..
be sure u have a charger plug-in or else if the battery is weak... u will have contact retailer....
well just format ur memory card first then post result..
Hope my info solves your problem,
Thanx for using fixya.
Oct 02, 2008 | Sony Ericsson W700i Cellular Phone
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare One Digital Camera Logo
110 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
