Question about Samsung ML 2010 Laser Printer
Copies are coming out streaky
I am on my second toner and it is supposed to be good for 10,000 copies. BUT i have only gone through about 2000 copies and now the copies are coming out streaky. Could this be a drum problem or defective toner cartridge...?
Defective toner. And a cartridge is only good for about 2000 pages - not 10,000.
Posted on Mar 20, 2009
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
When we recieve faxes they have black lines running down the entire length of the page. I have already changed cartridges and am wondering if there is something that needs cleaned? What can I do?
You have to determine if your FAX is the problem or the sending FAX has the problem. The first thing to do is make a copy or print a report. If it comes out clean you FAX is NOT the one with the problem. The sender has to get their optics cleaned.
On the other hand, if it's still "streaky" then your fax has a problem. First off remove the cartridge and look inside it, if you see toner get a can of compressed air (sold in office supply stores to clean keyboards) and blow out as much as you can. I suggest taking the machine outside the toner dust can make quit a mess. Make a few copies (5 - 10) to check it out. Each copy should come out with less misplaced toner.
Dec 07, 2010 | Brother IntelliFax-2820 Laser Fax
Our small office purchased a Canon Imagerunner 2000/1600 copier 4 years ago. Since our last service call, when the drum was changed and the machine was cleaned, we then ran less than 2000 copies. The...
When your drum was replaced did they put in a new drum assy or just replace the drum cylinder? I would purchase a new drum because these are one of the chepest to buy, around $ 80.00. They have a 6 month warranty and around 20,000 copies. I would replace the drum to see if that solves the problem. Before doing that, pull off the left side bypass assy. It is easily removed without tools. You should be able to see the drum and see if the drum is clean. If not, then replace the drum unit assy. Are you using only Canon toner, no other kind of brand will work. Generics should work but they are usually not as good a quality. The volume is very low and that should not be an issue. I believe its suppossed to handle 10,000 copies per month. Cleaning the glass top and below may help. The mirrors should also be cleaned as well. Good luck.
Dec 01, 2010 | Canon imageRUNNER 2000 Copier
Fax copy is streaky, almost banded looking. Copies the same too, streaky looking. Toner seems to be full, drum was replaced about 10 months ago with an after market one.
If they are black streaks and they are always in the exact same place, open the cover and clean the skinny little scanning glass. It might be ink or lint. If it's white streaks then it's in the same place but it's dried correction tape or fluid, etc.
Apr 27, 2010 | Brother IntelliFAX 2800 Laser Fax
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
The printed pages are coming out really streaky. We have tried cleaning it, but no joy. Any advice?
Print a few pages. As they are printing open the cover. Remove the toner cartridge. Look down at the page that was being printed. If it is not "streaky" look at the fuser, it probably needs replacing.
If that page is "streaky" replace the toner cartridge.
Jan 22, 2010 | HP Color LaserJet 2600n Printer
Toner Cartridge empty
does the display come up as "toner empty x"? what is the last character after the toner empty ?
where x is:
c=cyan= 6,600 pages
m=magenta=6,600 pages
y=yellow=6,600 pages
k=black=10,000 pages
Jan 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Light and streaky copies, and a powder residue.
make sure that the machine is level first. then you will have to change both the drum unit and toner cart with new units not just change the drum in the drum unit.
Nov 25, 2008 | Sharp AL-1641CS Laser Digital Copier
Streaky Copies
It dose not have a print head. But it dose have a drum. Are the streaks thin lines? Also, is only part of the copies fixed into the paper ( can you rub part of the copies OFF)? If you can rub off part of the copies - your problem is in the fixing unit. If the lines are fixed and can not be rubbed OFF you most likly need a new drum unit. Good Luck... Either way you will need a service rep. out to fix your problem
Oct 07, 2008 | Canon imageRUNNER 2200
Pages printing with streaks.
try making a copy on the glass, does it come out with the streaks or clean?
If clean then look at the strip glass on the copier there is a pen dot or white out that 's giving you the streak. clean.
Jan 24, 2008 | Toshiba e-Studio 232 Black and White...
Samsung ML 2010 Laser Printer Logo
142 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
