Question about Sony PlayStation Portable (PSP) Console
Psp turns on but some problems
Hi my psp will turn but the green light doesn't turn on and the circle button soen't work
  • 112 Answers
This is an internal problem it can't be helped.You have to give it for servise.
Posted on Jan 27, 2010
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Psp power indicater lights up green but does no turn on.
Hi.
It's probably bricked (dead). We need to know what's your last activity before it bricked. Mostly, bricked PSP is due to interruption during firmware update. Or when you install a CFW (Customized Firmware) by using ChickHen.
If your PSP is the slim type, you need to know what type of Motherboard it has. You will be lucky if you don't have a PSP with TA088v3 MoBo. Since you can no longer turn on your PSP, you will have no chance knowing the MoBo. But this procedure below is worth the try;
1.) Turn off your PSP by pressing the power button at least 10 seconds and green light is gone. 2.) While turned off, do one of the following until you boot into Recovery Mode;
a.) press the "R" button and hold it while pressing the power button. b.) press both "L" and "R" button and hold it while pressing the power button.
3.) If you are successful booting your PSP into recovery mode, google on how to recover your flash0 file...
Jun 03, 2011 | Sony PlayStation Portable (PSP) Console
When i turn the power button....the green light lights up......but the console wont turn on????...wat do i dooo????????
Did u tried to take out the battery for a while then put it back in to reset the device? I hope it works
Mar 25, 2011 | Sony PlayStation Portable (PSP) Console
WHEN YOU TURN ON THE PSP THE GREEN LIGHT GO'S OFF AFTER ABOUT
Hi! psp has a way of behaving, make sure your your power board is OK and that can be done by a certified technician because those problems are related to the power board.
Dec 23, 2009 | Sony PlayStation Portable (PSP) Console
Psp fell ,turn psp on.green light turns on.screen stays off
Hi first i will say sorry for that. I will recommend that you see a certified technician to fix it up, there are a few things i guess are wrong with your psp... the system of psp are fragile and should be handled with care because i think one or more parts are broken and need replacement. Cheers
My psp will charge but wont turn on
You'll need to visit a repair personnel to fix the PSP, the screen is damaged from you problem description.
This is the only way out for you.
Regards
Aug 17, 2009 | Sony PlayStation Portable (PSP) Console
PSP is not working at all
The PSP battery you are using may be damaged. If the PSP turns on, this shouldn't be a problem, but to fix the green light not showing, just by a new battery from Wal-Mart or K-Mart.
Oct 02, 2008 | Sony PlayStation Portable (PSP) Console
PSP Not Working
Hey, try taking the faceplate and screen off. Get a blowdryer and dry. This sometimes fixes the problem.
Jul 19, 2008 | Sony PlayStation Portable (PSP) Console
Power light on but still not working
Check ur firmware, (if ur PSP installed custom firmware e.g. OE, M33.) goto "recovery mode", press and hold R(right button) while turn on ur psp. if u can go, simple use pandora battery for downgrade/upgarde ur psp. see at, http://e-arena.blogspot.com
Oct 22, 2007 | Sony PlayStation Portable (PSP) Console
Power problems
Hi Gohan102,
Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
