Question about Candy DFI Plan Built-In Dishwasher
Candy Dfi 85s intergrated dishwasher
Stops just into run, beeping. I open door and water is cold.
Any idea please?
Barry
  • gerymoen Mar 20, 2009
    Turn on dishwasher after ten min starts bleeping lights flashing water cold Candy DFI 85 s integrated
Candy dishwasher wont turn on , lights are out , it is plugged in any ideas please ?
Posted on Apr 11, 2011
Water doesn't heat up and cycle seems to be stuck, candy DFI 45
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
Aug 19, 2014 | Candy DFI Plan Built-In Dishwasher
My Candy DFI Plan shows E3 and stops washing after 10-15 minutes. The problems started because electronics( I swithed with new) than I change the water pump, the heater, the thermostats and when is on,...
E3 - Water heating time out or fault
The dishwasher has failed to heat with water in a reasonable time or has failed to detect the water heating element.
Check water heating element wiring
Check wiring to main control module
Dado
Jul 28, 2014 | Candy DFI Plan Built-In Dishwasher
E3 - Missing heating of the water.
Could be:
· Clogged filtering plate.
· Defective heating element.
· Defective wiring (open circuit, leads
off place or loose).
· Defective electronic control board.
You have already changed all major electrical components energized during the heating phase. But do not forget that failures sometimes could be mechanical. For example: failure could be in hydraulic circuit of pressure switch, sometimes hydraulic circuit can lost air pressure. Another note would be that your dishwasher have NTC thermistor which every second gives information about temperature to electronic than electronic controlled heating element by a relay.
In order to heating element come under the voltage is necessary to fulfill a couple of requirements. Microswitch on the door in the closed position, the pressure switch in position 11-13 (full position , level of water) and the main switch is turned on.
24881895-svalokc2bmago0zdlfvpjh25-3-2.png Dado
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
It starts cycle and stops after a few questions but when i open and close door it starts again and stops...
Hello & Welcome to FixYa
The problem appears to be with the door switch as initially it starts cycle and then the control senses open door so stops the unit completely. Take a hair dryer and blow some air on the door lock/switch assembly, if this won't help then replacing the door switch/lock assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 08, 2010 | Candy DFI Plan Built-In Dishwasher
Candy cdi 1012/2-80 is leaking at bott of door. Whats up.
my candy dishwasher is leeking from the bottom of door what can i do
Nov 23, 2010 | Candy DFI Plan Built-In Dishwasher
1)My Candy DFI 50 is not washing properly, it leaves residue on the pots. 2)The programme controller on my DFI 50 seems to be sticking. Sometimes the dial doesn't move at all or takes 'hours' to run a...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 09, 2010 | Candy DFI Plan Built-In Dishwasher
I have a Candy dishwasher. Door is open switch on sounds like something (possibly pump) is running and error E4 shown on diaplay. Any ideas please?
Overflow tray (bottom dishwasher). Tilt your dishwasher, pour water and see the reason for the overflow. I blew off the top hose from the pump.
Jul 20, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Candy DFI Plan Built-In Dishwasher Logo
1,197 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
