Question about Combi Centre DX - Mango
Hazard light is flashing
I switched boiler on last night for radiaters but they didnt come on and its making a loud screaching sound. the light is now flashing.
    Problem Solver:
  • 5 Answers
It sounds like your pump bearings have gone, a new pump or pump head will be required, you may have a sealed system and a small leak may have dropped system pressure,causing the pump to run dry and damaged or seized bearings, if you have an older system with a filler tank in loft, the ball valve may have stuck in closed position and the water level has dropped in system. Venting the radiators on iether system can cause problems if there is not an adequate level of water.
Posted on Mar 03, 2009
How to fix my Worcester green star ri boiler?
The gurgling sound sounds like you have gotten air into the system. Try purging the air out at the bleeder valves. Also check and make sure that your water inlet is working.
May 29, 2016 | Water Water Heaters
Hazard warning lights activate when engine is turned off and car is parked. Any ideas please? Battery went dead due to hazard lights flashing all night
Sounds like a alarm system. I had an old car that did that untill I hit lock or unlock on the RF remote
if not check the Emergency flasher switch or maybe a relay. Of course make sure the button is not on. Try toggling on and off.
Mar 01, 2016 | Cars & Trucks
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
My ford falcon is draining the battery with the hazards staying on
Try checking the voltage of the battery after charging and disconnecting the leads.. Batteries die if being drained too much..
Jul 19, 2014 | 1999 Ford Falcon
2000 Subaru Impreza Sedan; Couple different noises
the screaching noise is 1 of your belts needs to be tightened. noise from the right front tire sounds like a bad sturt or ball joint and that needs to looked at
Jan 07, 2013 | 2000 Subaru Impreza
Potterton statesman utility boiler making screaching noise for 20 mins on start up then stops screaching and runs quietly!!!
Hi my boiler has just started to do the same. Have you had yours fixed and do you know what the cause was and how the problem was solved?
Thanks for a reply
Feb 18, 2010 | Heating & Cooling
My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
Dec 01, 2009 | Dryers
Combi Centre DX - Mango Logo
70 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
