I have an older computer (Dell Dimension XPS I believe) that I am trying to add a bigger hard drive to (500gb Western Digital). I had two small drives attached (80gb & 200gb). I already have my operating system installed on the 500gb drive, but any time I plug it in as the master drive with a slave drive I get a message that states "No Operating System Found" when I try to boot. If I hook up the 500gb drive as a slave, then everything works fine. I really need it to be the master, because I need to get my files off of the 200gb drive. Any help or suggestions (besides getting a new computer) would be greatly appreciated.
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
Is it an ide (flat wide data cable & 4 cable power cable) hard drive? There will be jumper pins near the data cable socket to set one as master and the other as slave.
Go buy an IDE hard drive of whichever size you want, and connect it to the IDE cable that your current drive is connected to inside the computer. If you don't want to reinstall windows, you'll have to either purchase a separate IDE cable and connect the new drive to another IDE port on your motherboard (IDE cables are the thin, flattned cables that are fairly wide) If your current IDE cable has a freed up connection, ensure that your drives are jumpered properly with the master/slave options that should be printed on the drive itself, with a diagram. Your main drive (34GB) should be the master, the new one set to slave - this will keep the computer booting off of your current hard drive. It may seem intimidating, but installing a new hard drive is easy once you open up the computer and start comparing parts, looking for your hard drive ports and power supply cables. Just make sure the IDE cable and the power supply cable are firmly attached to the new hard drive when you install it.(power supply cable usually has a white tip, with four loosely bound wires leading to it) I hope this helps!
1. Connect your 500gig drive as the slave of your smaller boot drive. 2. Go to http://freewareapp.com/western-digital-data-lifeguard-tools_download/ and get the Western Digital Lifeguard tools. 3. Run the executable to install WD tools. 4. Run that application.
You'll notice there is a Drive to Drive Copy utility. This will clone your new 500gig drive from the smaller drive. When the utility finishes copying the drive, shut down. Remove the smaller drive, and set your 500 gig drive as master/single. Reboot, and you should be running off the new drive.
It is possible that your old drive was an IDE drive and your new one is SATA. If so, you may need to enter Setup on the reboot, go to the Boot menu, and set the boot device to the new drive type.
If you have no experience with this, it might be easier to just copy the data from your Dimension to a external usb harddisk and then to the XPS. But i will try to explain it.
I've looked a bit around: your XPS hard drive is a SATA drive, while your the drive in your Dimension is probably a PATA-drive (just connection types. Look at the hard drives and compare them with this image to see which types they are.) As far as I know the XPS 530 has a Foxconn G33M-S motherboard, which contains one ATA (PATA) connector. So you should be able to just connect the hard drive from your Dimension into the XPS. To make it work properly, you should set the drive from the Dimension to slave. This can be done by setting the jumpers next to the cable connector. The jumper setting depends on your hard drive model. Usually the possible settings are shown on the hard drive. If you feel uncomfortable with this whole thing, you could ask someone, who has some experience and who you trust to do it for you, or just use an external usb hard disk
Make sure the computers are off and disconnected from the power outlet, when you open the case... Dell offers a user manual for your Dimension and XPS. Maybe it's of some help by removing and placing the various parts... Please tell me how it worked out. As you probably understand, I can't take any responsibiity for damage to your system... If you have any problems, just post them here!
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
Sorry. Posted this in the wrong section.
