Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
HALF OF AUGER NOT WORKING
I HAVE A CRAFTSMAN SNOWBLOWER 24'' 5.5 HP. AN OBJECT GOT CAUGHT IN THE AUGER HOUSING. I REMOVED OBJECT. NOW ONLY THE RIGHT HALF OF THE AUGER IS TURNING
When you got something caught in the auger, the shear-pin probably did it s job and broke, to save the gear box. Remove the old shear pin and install a new one
Posted on Dec 31, 2012
How to take auger out of snowblower
this is easy job look at it , it will show you how it is done , just look good at it you do not need anything to do this couple of hand tools
Feb 15, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Not sure how to reroute auger cable on craftsman snowblower
I assume the cable to the auger was removed and needs to be re-installed.
There should be a clamp that the cable ran thru, then attaches to the auger
control. Find this clamp on your snowblower, and route it thru this clamp
then attach it to your auger control.
Feb 25, 2011 | Garden
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
How to remove the belt from craftsman snowblower model C459 52560 MFG code 1/055/3-0079
Unfortunately like many other snowblowers you first need to seperate the auger/blower assembly from the drive/engine assmbly. Pretty straight forward after that. Make sure you put belts on the right side of the metal tab that cleans the back side of the belts when running or you'll they'll cut in two the first time you engage the auger
Dec 17, 2010 | Kitchen Ranges
1999 craftsman 5 hp 24 inch snowblower auger belt snapped . where can i get part number, or where can i find one.
I recommend contacting your nearest authorized service center, or you can download operators and service manuals typically online by performing a simple Google search using your make, model number and part needed.
I trust this information proves beneficial.
Jan 03, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
404 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
