Question about Technics SL-1210 Turntable
Broken cover Hi ive just dropped a small speaker on my SL-1210Mk2 luckily i had it closed, but it hit the cover and put a crack the whole way across. i know it does not stop me using them or has no real affect on them but id like to know if i could purchase a new one?
  • 515 Answers
Turntable hits bottom
then it's time for a new one, but the platter touches the underground: be smRt and replance the centre shaft, since you have an 1210mk2 and they need replacement. it's 40 euro. and you'll notice the difference after many years using an old one
Mar 14, 2014 | Technics SL-1200MK2 Turntable
Why is the right side of my Technics turntable dropping out and giving me a ground hum?
It sounds like a bad connection to the cartridge, perhaps even the cartridge itself.
Feb 02, 2013 | Technics SL-1200MK2 Turntable
Hi i have dropped my d50 and err comes up
There is a motor/gear assembly inside the camera that moves the lens in and out and covers the lens when it is retracted. When it dropped, you most likely cracked or shifted something out of place. A broken tooth does not stop function, but shudders when it hits the gap. A shifted gear, slips and similarly may cause this effect. If it doesn't open the shudder, you get no picture.
You will need to open it up and attempt to repair the mechanics that drive the lens.
May 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
My screen was hit with a doorknob and has a crack
It's cheaper to buy a whole new TV. I recently acquired a similar TV with a broken screen thinkink I could get a screen cheaper than a whole new TV. I found out different. If you find a place to get a screen cheaper than a new TV I would like to know about it.
Dec 08, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My speaker stop working
Hi
Check the sound drivers in your system and also check whether the speakers have been properly plugged into the system
Thank U
Please rate me as it wil cost u just one click
Oct 23, 2009 | XRS 797 Radar Detector
Fried my electrical supply...
hi aris tomas...1st check the fuse inside the turntable..then if its ok go to the main board  ..check the zener diode (D3)  and the transistor Q3 and Q2...the fidbk me wat hapen , if possible if you can chance it replace it..u
Jan 31, 2009 | Panasonic Technics SL-1210MK2 Turntable
Deck speed up to uncredible speed and wont stop
You both have issues with your drive circuits. There is no easy fix for this. You will have to take it to a repair center to have them serviced.
There are 4 main Integrated Circuits that control the speed/drive and any one or all may have gone bad. We are seeing this alot with these units now.
Wish I could be of more help.
- OPTiC
The 1200s Expert
www.1200s.com
www.repairnyc.com
DJ Pro Audio
Aug 23, 2008 | Technics SL-1210 Turntable
Technics 1210mk2 turntable
Hi Dezzy
Go look here There is heaps of information on your deck. There is not alot to service, just some adjustments. If you have any problems with the T/T, got back to me here. So spruce em up and go drop some nasty tunz:)
regards
Graeme
Mar 07, 2008 | Audio Players & Recorders
Internal fuse
remove platter remove plastic cover main fuse is there
Jan 29, 2008 | Technics SL-1210 Turntable
Broken / Cracked display
Is it just the plastic cover over the display? I think that would be a little easier to find an replace than the whole display would. Garmin does stock alot of parts for their units. Unfortunatly, alot of the small electronics thats built today is disposable. The components are all small surface mount stuff packed in on very small double sided pc boards....this is very hard, timely and expensive to track a problem. For that reason alot of manufacturers do not supply parts for certain models. This MIGHT make the actual display harder to find..... but in your case its just the display cover.... the odds are good you will find one. Check at the Garmin website...they will have lists of certified repair shops with access to parts.
Aug 24, 2007 | Garmin Rino 120 2-Way Radio
Technics SL-1210 Turntable Logo
150 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
