Question about Whirlpool WED8300S Dryer
Whirlpool Duet Sport Dryer PF code
I've looked up the PF code on this site and people say simple power failure. Most people who explain the problem say this trips the breaker. Mine is not tripping my breaker. It happens when I use timed dry over 30 minutes.
The support guy came out, replaced the control board....did not check temp sensors or anything else. Said if the control board didn't fix it, it would be time to call electrician. I think it's an issue with the dryer. The grate on the back of the dyer (the silver one) looks rusted or scorched and I've had temp issues before. Like I said, it's not tripping the breaker either, the machine is resetting itself. Any ideas?
PF code keeps coming up. Some days it shuts off repeatedly and other days runs fine. Best Buy tech replaced machine control electronics,console electronics, and checked wiring conections. An electrician checked the wiring. Its fine. voltage 118 to 120 volts. Called Best Buy again. They are sending a subcontractor out.
  • stevemc4242 Mar 13, 2009
    All of a sudden after 18 months, my dryer keeps shutting off the cycle and showing the PF code anytime I try and use the timed drying feature. It shuts off at different intervals but doesn't every make it through the whole cycle. I've sat next to the dryer and as soon as it stops spinning I look and the PF is showing. If it loses power it certainly seems to be coming back on instantly. It has never tripped a breaker.
  • tomlat03 Apr 11, 2009
    I replaced the control board as directed ...still will not start..I know it has correct voltage/breaker good???
  • 4 Answers
I just posted this webpage that has the answers to your problem.
https://sites.google.com/site/duetsportpfpowerfailure/
Posted on Apr 18, 2009
2 Suggested Answers
SOURCE: Whirlpool Duet Sport Dryer PF code
dmarshall05 again:
Two technicians have been out (new guy & experienced guy). First tech didn't take lower panel off, but 2nd tech did and found that drying vent tube (4" tubing) had disconnected. I replaced the rigid vent that came with it to vent to the left side instead of the back. That was 6/3 and today is 6/6 and it hasn't happened since. It was happening every load where it would run 3 minutes and shut off, then cool off for 5 minutes, run for 3 ....
Check you vent tube. I'll post again if this turns out not to be the solution.
Posted on Jun 06, 2008
PF code comes on
Check all the wiring to the dryer and even the wires in the wall socket. Sounds like there is a loose wire since you keep getting the power failure (PF) code on the dryer.
Dec 27, 2011 | Whirlpool GGW9868K Gas Dryer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirlpool duet dryer error code pf
The error code means that the unit suffered from a power failure.just make sure that all the wiring is good there is nothing loose and the circuit breaker is in good shape you should be able to turn off the dryer unplug it for a few minutes and the plug it back in this should clear the fault code.
Feb 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Whirlpool Duet sport dryer that came with the house I bought a year ago so I have no manual. What does it mean when the display says PF? Clothes were dry but display waid PF
The only PF I am aware of means power failure. Try unplugging the unit for awhile then try it again. This may reset the computer.
Feb 14, 2010 | Whirlpool Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
Whirlpool duet gas dryer PF error will not reset as per manuals
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
PF Code on Duet Electric Dryer
just press cancel ..pf means power failure ..if still not clearing probably control
Aug 15, 2008 | Whirlpool GEW9200L Electric Dryer
After ranting and raving about similar issues with my own Whirlpool Sport, with no success from a ton of repairs and technicians, I decided to check the exhaust vent from dryer to outside - thinking that the dryer must be sensing an overheating problem to trigger internal shutdowns without tripping the house breaker. Sure enough the vent flap on the outside of the house had become stuck, instead of flipping open when the dryer is working. I fixed the vent flap and the problem was solved. So check all aspects of the venting - a squashed flex hose, stuck or partially closed vent flap, something covering the vent. Sometimes the simplest solutions are the correct ones.
Mar 10, 2008 | Dryers
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
1,089 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
