Question about Kenmore Elite 45986 Front Load Washer
Washer won't spin- flashing "f 02"
My Kenmore Elite Quiet Pak2 washes but won't fisnish with a spin cycle. It just flashes F 02, any suggestions?
  • buffbaby2001 Mar 03, 2009
    Kenmore elite HE4t stops washing and flashes f02
  • Anonymous Mar 09, 2009
    same problem
In the HE3 series it means the drain tube or pump is clogged
Posted on Mar 10, 2009
Kenmore elite quiet pak2 washer-in the time remaining/de l at display a y, digital numbers are flashing and sometimes read08,8:88,0:88 and when I choose a setting and press start the machine locks the
Sounds like the control panel is defective or you have a stuck key on the unit. Check the control panel for any obvious cracks, damaged, etc. if all else fails, you'll have to replace the control panel.
Jan 09, 2015 | Kenmore Washing Machines
I have a kenmore elite total care flex king size capacity plus quiet pak2 oasis that makes loud noises like a airplane when its in the spin cycle Model #110.28032701 which parts should be change?
If the washer is roaring during spin, the bearings are bad and you will need to replace the outer tub assembly.
Here is the part to order.
The part comes with a 365 day, any part, any reason return.
Nov 03, 2012 | Kenmore Washing Machines
Control Locked light on
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the DRAIN/SPIN button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Kenmore Elite 45986 Front Load Washer
F 02 reading on front loader washer.
I found several helpful sites from owners who had the same problem and they got the issues resolved, will try what they advised and if that don’t work I’ll call a service technician.
Oct 01, 2009 | Kenmore Elite 45986 Front Load Washer
WONT RUN COMPLETE CYCLE WITHOUT F-2 OR SUD
sounds like you have a clogged/bead pump. removethe lower acess panel and from there youll see the pmp clean put remove thescrewout, and clearthe debris. BE WARNED THER WILL BE WATER BEHIND grab a towell or 2
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
I have problems with my kenmore elite quiet pak2
hi thanks for the question the dlf code for the duet says drain pump remove bottom panel the pump is on the right but there is a big nut in the front remove the nut use bucket as water will come out and clean filter thanks please accept and a positive feed back is nice thabks the appliance doc
Sep 17, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
853 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
