Question about Canon Powershot SD450 / IXUS 55 Digital Camera
Canon sd450 possible battery problem?
Ive had my camera for almost 3 years. now, when i charge the battery and put it into the camera, i can take 1-2 pictures and then the dead battery light blinks
however, i know the battery is charged because the green light shows up on the charge
do i just need a new battery? or can this be a camera problem?
thanks!
  • 60 Answers
If you have charged the battery many times then after 3 years that could be to 90% your problem.
Firstly try to clean the battery contacts and camera contactswith cleaning alcohol or contact cleaner.
If that does not help, it is a new battery.
Posted on Mar 06, 2009
I am unable to find a new battery that works in the camera. Original Battery: Canon NB-4L 3.7V 760 mAh I have tried two different: Flashpoint NB-4L 3.7V 890 mAh to no avail
You can order the NB-4L battery from Canon at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd450#SuppliesAndAccessories
(If FixYa screws up the formatting, go to http://www.usa.canon.com , enter "SD450" into the search box, then click on "Supplies & Accessories".)
You'll also find a variety of third-party options at
http://www.overstock.com/search?keywords=canon+nb-4l+battery
Feb 14, 2011 | Canon Powershot SD450 / IXUS 55 Digital...
My Canon PowerShot SX10 IS WILL NOT turn on , ive tried everything , and ive even gone on youtube to look for videos to fix it , i cant find any . ive had the camera for 3 years
HI..
The possibilities to consider for this kind of problem are quite a number
the bateries you are using might be defective, so you can get a new set of bateries with the voltage and wattage or charge the old one appropriately..
the contact for the battery could be the problem if there is rust in it. this would need cleaning..
the power switch of the camera might also be faulty, this would require you to take the camera to a repairer.. if you got warranty on it you can consider using it or look for a good engineer around you to fix it..
i hope this information will help you
Feb 04, 2011 | Canon PowerShot SX10 IS Digital Camera
Camera is 3 years old. Lately I take a picture
All the battery have a life time fixed working hours. Your battery is charged but he complete is working time. Thats why these msg will come. Dont warry use the battery when you see the power going down after a while of charging then change the battery and buy new 1. Good luck.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
Batteries discharge quickly even if the camera isn't being used. I have three batteries and two are over one year old.
Hi
It is recommended that if batteries are not going to be used for long periods they should be removed from the camera altogether during that time.
If you are referring to rechargeables the ability to retain charge is effected both by the age of the battery and the number of times it has been recharged.
Canon cameras are generally one of the better cameras in terms of being economic on power. It is likely that this problem is battery related and not camera related.
As it is also important not to mix old and new batteries together - I would recommend that you purchase new rechargeables. Three new rechargeables batteries in your Canon should resolve your problem and give the best results.
Thanks for using FixYa.
Oct 02, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
E18 error on powershot canon
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Sep 27, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
My Canon SD450 turns on but the screen is white in
have u asked Canon i think tey will do it FREE as all are doing it with same problem it is a CCD PROBLEM if u have same problem then list doent make any sense
i hope it helps
pls rate me well
Jul 07, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Canon Powershot SD450 batteries don't deliver
Canon nb-4l battery sell well in UK,one year warranty and one months refund guarantee.You'd bettery buy replcement canon nb-4l battery and nb-4l battery charger that heard from your friend have buy and use for a long time.
Jan 17, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Canon Powershot SD450 got wet, would not work for a month, works great now but won't turn off. turns on by itself when you put the battery in.
hi - just managed to get mine working again after adventure in washing machine 6 months ago! I was previously at the same point i.e. not possible to turn camera off. I have just removed all ribbons from front pcb as well as the connection from the control panel ribbon under the lcd. Cleaned all ribbon contacts with alcohol & reassembled - now it works.
Jun 13, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Canon sd450 - spilled a little lemonade on the camera
maybe the lemonade was sticky and the shutter can't open? otherwise the circuitry could have been fried if you turned it on before it dried inside.
Nov 09, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
219 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
