Question about Avanti Refrigerators
Digital reading stays at 39 degrees so cooler compressor doesnt kick on
  • MEshleman Mar 02, 2009
    Adjusted thermostat and reading stays at 39. I dont know how or where the thermostat is located to check. Plus I dont have the tools to do this.
    Digital reading stays at 39 degrees so cooler compressor doesnt kick on. Have adjusted thermosta to no avail. Even have unplugged unit overnite and the setting stays within a couple of degrees of 39F.Consequently the compressor doesnt run long enough to cool items. Sometime digital number radomly go as low as lower 20's as if thermosta no working properly. Dont nknow where thermosta is located plug do not have tools or eqpt ot check if properly functioning..Please help
  • 423 Answers
Hi and thanks for coming to FixYa.
I would check your thermostat. The thermostat checks to make sure how cold the unit is and when it reaches the desired temperature, it kills the power to the compressor.
It is located directly behind the temperature selector. If you don't have the tools to check it and/or not sure how, then just replace it. It's easy to and doesn't cost much money.
Make sure you unplug the refrigerator. Take the temperature control off, it should just take common philips screwdriver. Get to it and remove the power leads. (Write down the color combination so you don't forget.) Got to an appliance repair shop and show it to them. It should have the numbers on it so you get the same one. If not, they can look it up at the shop. Then take it home and replace. Don't worry, it's easier than you think. Let me know how it goes!
Rob
Posted on Mar 02, 2009
    Scholar:
  • 165 Answers
As you stated compressor does not  kick on check out this Compressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps  ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example oneexample twoexample three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install areplacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed.
A few things to check for is - power at the outlet, check for 120 volts. If the light inside the fridge works, the defrost timer,cold control and possibly the wiring are the most common things that can make a fridge sit there and be "dead", not running. The defrost timer might be stuck in defrost, turn the timer screw to advance the timer and if the fridge comes back on, replace the defrost timer. You can join the wires together to by-pass the cold control for a test, if the fridge comes on, replace the cold control.
    Sergeant:
    Novelist:
  • 277 Answers
The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system,.
and you will have to replace the thermostat.its faulty.
  • 13,433 Answers
The temperature sensor is possibly faulty, have you considered replacing the sensor to see if that solves the problem?
How the warranty? is it out?
  • Ekse Mar 02, 2009
    That was my mistake, the temperature sensor is not related to this at all. Suggest to follow ginkos advice in this case. Thank you, please repost over my solution.
    Brigadier General:
  • 3,614 Answers
adjust the thermostat, chect and test if this part is faulty
  • Avanti Master
  • 19,396 Answers
That means that you may have a faulty thermostat.
Cooler Compressor runs but cooler won't get cold?
If the compressor kicks in then check the lines to see if they are cold. It is possible the compressor burnt out from leaving the door open. Purchase a sensor alarm to alert you if the door is left open.
Nov 16, 2013 | Coldtech S3BRR-18S Commercial Refrigerator
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Unit does not get cool. I can hear the compressor kick on, but it goes off about 15 seconds later. After a minute or so it goes on again only to shut off again
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 13, 2011 | Danby Silhouette DWC512BL Wine Cooler
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
We have a MXZ-3A30NA that does not seem to be cooling down the house. Indoor temps are reading 75 to 78 degrees and the units are set at 65. We have gone through the book and have followed the check list...
Hi!!
Check the following:
Make sure the filter and the evaporator coil are clean. Also check condenser coil in the outside unit is clean.
When unit is turned on there should be (on the led display, inside unit) one green light on for the blower and another one for the compressor, both lights should be ON untill the unit reaches the preset temp. If the light for the compressor (usually the light on the right side) does not stay ON, check the outside unit.
On the outside unit, check that when turned on, both the fan and the compressor kick in and stay running. If the fan motor stops, the compressor overheats and the thermal proteccion shuts it down to prevent damage. Also, if the R22 gas is low, the low pressure switch prevents the compressor from running.
Good Luck!!
Aug 04, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Freezer runs constantly,seal is okay,frost free,have tried lowering the temp,food stays frozen. zeecudaboro@tds.net
It seems to me that the thermostat is no longer sensing temperature. IT will either stay on (it controls the compressor) or wont come on at all when it becomes a problem. You can order one thru sears.com if there is not a appliance parts store nearby. To check before buying, heres what you do. You need to know the temperature (use a thermometer that reads below zero). it has to be at least 10 degrees or cooler. if it is then turn down thermostat dial to 1. if it shuts off then the thermostat is ok. if it doesnt turn off (the compressor) replace t'stat. let me know the temp. and if this works for you hope this was helpful...
Mar 30, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's "Klixon" overload. Call a commercial refer guy (not somebodys brother in law that works on A/C, it's NOT the same!)
Jul 15, 2008 | True GDM-26 Refrigerator
Keg freezing!!!!
Same problem here. Can you give me their number? cheekychap@bellsouth.net
Feb 20, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Refrigerators Logo
26 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
