Question about Philips 15PF9925 15 in. LCD EDTV
Wheres the audio out
I want to run the tv through a amp. which ext would be the audio out
  • 90 Answers
Audio out connections
Posted on Mar 03, 2009
Just bought 1999 mitsubishi model 60603. I have dish network I get pic no sound
Get an audio cable that will fit in the audio out of the dish receiver and connect it to the ext audio in on the TV. Go into the audio setup menu on the TV and select ext audio.
Aug 07, 2016 | Mitsubishi Televison & Video
Where is the audio out on rank arena tv model sv-42h1fhd100
my samsung has it on the back 3.5 but it is for external speakers with external amp.plug in headphones very little volume.tv volume will not work when switched to ext.speaker. note this is the way mine works if yours is the same by an adapter with a 3.5 end and 2 rca plugs on the end plug them into the in on the cd player etc.
Feb 24, 2015 | Televison & Video
No audio. good video
Not familiar with this make of TV, but some TV's require you make a change to the audio menu from int. to ext. speakers. Do the internal speakers work and if they do, besides the menu change are you useing an external amp with your surround system?
Aug 23, 2012 | Polaroid TLA-01911C TV
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
How do we hook up speakers to our lg 42 inch tv, at the store we didnt realize it only had speakers in the back of the tv which hinders the sound?
depending on your model look in the back or side for (ext speakers) audio jacks out...this is where plug your ext speakers...if you are plan on using a 5 to 1 stereo receiver the speakers will be plug into the rec...
Jun 06, 2010 | LG 42LC2D 42 in. LCD HDTV
I have no audio on my RCA Scenium rear projection
Replace Audio output ic. Make sure you do not have sound turned off.
Sep 28, 2009 | RCA Televison & Video
Sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Nov 17, 2008 | Sharp Aquos LC-32D40U Television
Wharfedale LCD37F1080P and external surround sound
  1. hi here is what you do go into menu go to feature thento ext 2 out then press right blue button on remoteand find the ext you need make sure your tv volume is turned down make sure your surround sound is on and turned up wait and you will here your sound when you have the right ext i have hdmi lead in ext 5 so it ext 5 that will show in the feature menu i hope you find your problem solved allan
Aug 09, 2008 | Televison & Video
I have NO sound!
Check for two locations - on the back of the set itself, lower right hand side. A switch for the speakers (EXT -up-, INT -down-) should be in the down INT position for the TV's internal speakers. Also on the TV screen go to MENU> AUDIO> SPEAKERS> press enter to check the ON button. Of course the other option is a separate amp (using the rear Audio Output RCA jacks), or below that the LEFT/RIGHT external speaker connectors.
Oct 16, 2007 | Proscan PS38000 TV
Philips 15PF9925 15 in. LCD EDTV Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
