I have a Panasonic Mini stereo SC-CH94M bought in 1996. Recently a CD blocked in the carrayer. I had to opened-it to take it back in place. Now, the carrayer indicates an error message when I turn it on. He is trying to scann the disks 3 times, but it stops at the begening and it is traying to move to the left and does'nt scann all the way to the right. After the error message, the groop "F" is highlited. Is it possible to reset the CD player? Thanks Michelrvenne@videotron.ca
  • 3 more comments
  • michelrvenne Mar 02, 2009
    SC-CH94M It use to work OK.
    This is not a problem of reader, This is a problem at finding the wright CD on the list?
    I know I can bye an other one,
    It was working OK yerterday it is just a matter of having the carrayer finding the disk.
    Do you think is possible to find the manuel for this Unit?
    hbsurfdawg thanks for your reply,the Reader is moving along on the track but stops at the begining of "B" location on the track and does not run completely from one side to the other and refuses to mount any disc, (It was going OK yesterday) After three try it stops and indicates error and the button "F"section is litten.
    But the carryer is stop at "B1". Thanks Michel
  • Eric  Kirkhuff
    Eric Kirkhuff May 11, 2010
    I am familiar with the Panasonic and back then they had some Readers that would fail to move along the track and read the disc. If you are getting an error it is about 85-90% the IR or Infrared is ok but it sticks on this delicate track. Back then we could replace it, but it not worth doing... for that I am sorry.
    Unless this has sentimental value, it is not worth pursuing and you to answer your question there is nothing that you can reset to get it to work properly.
    One question . Can you play Any CD's at all consistently?
    If so, then it plays only that format. CD's today use different formats from 1996.
    If you find one that works, then that format will be the one that plays and you can use it to play Only that format.
    it will not play mp3 or any recent recordings that are done on a computer or from a friend unless it is recorded in that older format.
  • 4,234 Answers
Every time that you power up the unit it performs an internal reset/test. The failure you are seeing is caused by the mechanism being "out of time". Unfortunately, the only way to resolve this is to dis-assemble the unit and re-assemble in a particular order with the parts "aligned" properly. This is not a simple task and will require the service manual to indicate the alignment points. I have done a number of these and they are not the easiest. If you are off by 1 tooth in a cam gear the unit will not work properly. I would suggest that you take this to a Panasonic authorized service center. They will have the instructions and jiigs to insure proper assembly.
Dan
Posted on Mar 02, 2009
    Sergeant:
    Novelist:
  • 277 Answers
The carriear whiuch you r mentioning as you removed and refitted.its not that easy as when you remove it will be set at particular allignment and when you refitted it that exact proper company allighment is got disturbed so its not getting detected and this is happening.just refitt everything again and again till it grets perfect.its just the fitting error.it should be exact as orignal.otherweise it will not support.there is nothing like pressing buttons and it will reset.
  • 19,396 Answers
That is not a matter of reset.
The CD starts reading and as soon as the lens is moved detects an error, and goes in Fault mode, that is the F.
It can be a lose contact to lens pickup, a damaged lens pickup, or a mechanical problem.
The unit must be taken apart and tested to fix this.
Better if the job is done by a technician , if you DIY follow the service manual to do the repair.
Start checking the contacts to lens pickup.
Check if belt is ok, belt and motor should be fine.
If you do not find any mecanic fault , then replace lens pickup, try cleaning it first.
repair must be done by a qualified technician
You can find parts and service manual here
    Scholar:
  • 165 Answers
The error which tyou stated is the unit in stand by mode.it cannot be resetted as there is a memory chip in this units this chiops has to be replaced to make it proper but the unit is very old and the memory chips are not available witrh the dealer or the servicenters.it has to be replaced.this will not get resetted as nothing can be donne.
  • 564 Answers
Thank You For Choosing FixYa!!!
Jus give me minute. Let me Check the manual.
  • Prem  Kumar
    Prem Kumar Mar 02, 2009
    It seems to be a lens problem, Jus try to clean it. If still have same problem take to a repair shop and tried to change it.
    Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
    PREM
    Sergeant:
  • 239 Answers
Unfortunatly there is no way to reset the cd player.
it sounds as thought has a problem with hardware in the carrier.
you can take it in to a repair shop and have them try to repair it, but it would be cheaper and faster to just replace the whole unit.
I hope everything works out.
best of luck.
please rate good.
  • 13,433 Answers
This is probably a dirty or dusty lens, or possibly the optics failing, please try a cd lens cleaner and canned air and then try again.
  • Ekse Mar 02, 2009
    if the tray/ carrier is offbase and not where its supposed to be that could be the problem instead of the lens.
    Can you tell me more about the error message you receive?
Panasonic stereo system sc-ch64m,sc-c649 ser#du6gb61971 or 0u6gb61971 ON MOVING INTO NEW PLACE UNIT JUGGLED AND ALL CDS FELL INTO BACK OF UNIT. THE DOOR WOULDNT OPEN SO I COULD REMOVE CDS SO I...
Hi Sam,
First of all, thank you for purchasing the service/repair manual of Panasonic SC-CH64M.
Please email me at mjsvillanueva23@yahoo.com, I will send you the copy. It is a pdf file format and can't be uploaded here.
Again, thank you so much!
Rating and feedback are highly appreciated!
Kind Regards,
Mjsazon
Jan 14, 2012 | Panasonic Audio Players & Recorders
Cannot control iphone menu with remote
Many stereos aren't fully compatible with iPhones. You can either look for one that says iPhone compatible, or live with it.
Jan 08, 2010 | Panasonic SC-HC3 Mini Stereo Audio System...
Panasonic cd stereo system sa-ak100
my remote control don't work. I thank it's the remote control signal sensor. what should I do.
Jun 20, 2009 | Panasonic SC-AK100 CD Shelf System
Problems with the panasonic cd stereo system
problems with the panasonic cd stereo system for some days.
The model no is SC- AK640 and i have been experiencing such problems such as "F61" and in the operating guide it says to check and correct the speakers cords i have done that but the problem can not be fix so please if you can assist me that willl be great thank you
Aug 31, 2008 | Panasonic 5 DVD/CD Micro System with MP3,...
No antenna, no radio reception
If the model number is SC-AK630, please confirm. The antenna should still be available from any Panasonic part distributor. Please confirm the model and I'll get you the part number and cost.
Dan
Jul 29, 2008 | Panasonic SC-AK630 CD Shelf System
37 people viewed this question
 Grubhead
Grubhead
