Question about Frigidare FGB24S5DC Gas Single Oven
Door hinges appear to be sprung
The door does not close completely, consequently the oven will not pre heat correctly. The switch that would be engaged by shuting the door does not engage, so the light stays on. Does that switch also effect the oven elements as well as the light?
Can sprung hinges be repaired or replaced?
Oven is only 2 years old.
    Sergeant:
  • 416 Answers
Pull up alittle on door then back down to seat the hinge
unless you put something heavy on door , this should work
Posted on Nov 20, 2013
3 Suggested Answers
SOURCE: adjusting the oven door hindges for a snug fit
i wanna circuit board of inkjet printer and faluts finding
Posted on Dec 19, 2007
DeBruce
  • 145 Answers
SOURCE: removing dust from inside the oven door
We buy DeBruce Polish at debruce polish.com, this stuff will remove the rust and pacify the surface.
Posted on Aug 18, 2009
Oven door seems sprung as if a spring may be shot and door dose not close all the way?
You need to replace both oven door hinges, as the springs are weak, and there is no adjustment available.
Sep 25, 2010 | Cadco OV-400 Electric Single Oven
Error message F64 appears when lower oven is turned on.
Hello,Note that lower oven cooling fan air switch not detected and that means you have to replace air switch,replace cooling fan,check connections,check P6 on PCB control display.
Thanks
May 31, 2010 | Thermador C272 Electric Double Oven
Kenmore 790.49073400 oven door won't close completely
Hello- You are on the right track. The hinge assemblies are 'sprung' or bent out of shape. Replacing them is pretty easy, so you can do it yourself. Four screws on each side. Be careful, these springs can snap closed and bite ya. Use the little pins that come with the new set to lock hinge so this doesn't happen. Let me know if this info helps- have more if needed- Thanks- Ed
Mar 19, 2010 | Kenmore Ovens
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
Oven door not closing correctly
I had the same type of problem. I unhinged the door then disassembled the door (it's really quite easy)
after you take all the TORX screws out the everything comes apart! Don't worry about the screws putting them back is a snap! Now that you have the door apart take the door hinges out of the inner door plate.
If you look at then closely they will have a slight bend in them. Pay attention to how they would have been positioned on the door! Simply bend them slightly I used the edge of a step! My door now shuts completely! I hope this info helps many of you having the same problem! If you take the time it really is amazing how easy it is to solve the door issue! Thanks to my buddy RON.
Aug 06, 2008 | Bosch HBL 435 Stainless Steel Electric...
Oven light
Heat causes metal to expand. Expanding metal can make contact with other objects, like a ground that completes a circuit. Take the lamp assembly apart and check for exposed conductors. Also, check the door switch. If it is heating up and something within the switch is expanding then the switch may be closing due to heat. With the door open puch the switch all the way in and see if the light goes off. If it does then replace the switch.
Deepwater
Apr 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
Frigidare FGB24S5DC Gas Single Oven Logo
158 people viewed this question
Top Frigidare Ovens Experts
Dan Webster
Dan Webster
bobalix
Are you a Frigidare Oven Expert? Answer questions, earn points and help others
