Question about Southwestern Bell Lands Phones
Instructions for SWB phone model FF925
I was given thic phone in good working condition but do not have the instructions to setup the phone . Model FF925, 900 mhz. It is a digital answering machine.
5 Suggested Answers
PyroMan6x9x9
  • 150 Answers
SOURCE: Radio Shack Digital Answering Machine Cat #43 3825
No problem, follow the below link for your manual. http://support.radioshack.com/support_phones/doc72/72809.pdf Good Luck L8R
Posted on Sep 17, 2007
oldnovii
  • 667 Answers
SOURCE: instructions for model 1188
Hi Diana - To record your outgoing message, hold down your ogm button ( outgoing message) for two seconds and it will ask you to record a message. To play back your message, just push the same button and it will play your message. If you don't like it just do it again. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good day.
Jeff
Posted on Jun 11, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: setting time, changing #rings
Here's a link to the manuals download page at Uniden. Pick whichever is the model you have.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Posted on Nov 19, 2008
axebro112
  • 56 Answers
SOURCE: How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Posted on Mar 19, 2009
SOURCE: Lucent Digital Answering Machine Model 1715
If you search for an AT&T Digital Answering machine model 1715, you will be sent to a free service with an abreviated manual.
Posted on Jul 25, 2010
Need the code to reset messages from another phone
If you haven't changed it, the security code is 80.You may download a copy of the manual here. The instructions for changing the security code are on page 41. The remote access instructions begin on page 45.
Apr 20, 2012 | Uniden 5.8GHz Expandable Cordless Phone...
I have a GE phone answer unit Model 29871GE3-A. It keeps saying the wrong day and time (about 13 hours ahead). How do I set it right? Thank you very much, God bless.
Press and hold the SETUP/ENTER button for two seconds to access the setup menu. After the language you can change the time and date.
Full instructions are in the "Changing the Settings" section beginning on page 10 of the manual. If you need a manual you can download one at
http://www.home-electronics.net/ge/pc/IB/29871GE3_IB.pdf
Apr 28, 2011 | GE 29871GE3 Digital Answering Machine
How do I set the number of rings before the machine kicks in? I have model number 1710 AT&T.
There should be a setup button.My machine looks to be the same,just an older model.When you press the setup button,it will tell you the current setting.Press memo/repeat or annc/skip to change higher or lower numbers.After you have the setting you want,press the setup button until it exits the system and it will repeat the settings you have selected.Mine also has instructions molded on the back,but nothing for setting # rings.Good luck,Greg
Feb 17, 2011 | AT&T 1717 Digital Answering Machine
How do I put a new answering Message in the system
Since you neglected to specify the model of your Uniden 5.8GHz cordless system I can only suggest you select it from the list beginning here to download the manual.
Apr 03, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
How do i forward calls to another phone when away from home? I have the 5.8 GHZ model
Call forwarding is a service provided by your telephone company, and the procedure varies from company to company. Please contact your telephone company for instructions on forwarding calls. And don't forget to get the instructions for cancelling call forwarding for when you get home.
Dec 30, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
How do I check my messages when I'm away from home.
Regarding your model number TRU9485-3 5.8 Uniden phone, you can easily access your answering machine remotely by following these simple instructions from the official Uniden web site. Click the PDF user's manual link below.
http://www.uniden.com/pdf/TRU9485-3om.pdf
Once there, look on the left-hand side of the page and scroll down to where it says, "Remotely Operating Your Answering Machine" and click.
I hope this helps you!
- CBR2009
Aug 26, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
I am In possession of South western Bell Freedom
Here is a direct link to all Southwestern Bell's products - Manuals - and Accessories!
http://www.swbfreedomphone.com
The phone number for their product support is
1-800-366-0937
they are open M-F 8:30AM - 9:00PM EST and
Sat 8:30AM - 12:30PM EST
Thanks
Len
Need more help? Just ask! We'll dig further!
Mar 08, 2009 | Southwestern Bell Lands Phones
Lands Phones Logo
94 people viewed this question
Top Southwestern Bell Lands Phones Experts
Outback Jack
Outback Jack
Are you a Southwestern Bell Lands Phone Expert? Answer questions, earn points and help others
