Question about GE WBSR3140DW Top Load Washer
Washer will not drain
I WASHED BATH RUGS AND AFTER THAT WATER WILL NOT DRAIN FROM WASHER, WHAT CAN I DO
  • GE Master
  • 3,361 Answers
Remove the front panel. Remove the drain pump and clean the debris from the drain line and the drain pump.
The service sheet is located inside the control console with the procedure to remove the panel.
Posted on Mar 04, 2009
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
MY FISHER & PAYKEL WASHER STOPPED AFTER RINSE WHEN I WASHED BATH RUGS THAT FELL APART. IT WON'T DRAIN AND MAKES A WHINING NOISE WEN ADVANCED TO SPIN CYCLE. WHAT SHOULD I DO?
Your pump is blocked with the bits from your wash. A handyman may be able to service the pump, but it would be a quick job for a tech. The pump us accessed from under the machine and can be inclipped like a light bulb. Inspect carefully first. look for small latch clip before twisting. Make sure the machine has been bailed out first. lean the machine back againt the wall to give access and to keep what little water remains, away from the drain/pump hole. Good luck....Nomess
Jul 13, 2010 | Fisher and Paykel Washing Machines
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
My washer will not drain . I washed bathroom rugs that fell apart leaving excess fibers that I beleive plugged up the holes that allows drainage. A few gallons of water is still sitting in my washer and...
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi..we washed a rubber backed rug and the rubber came off and the water will not fully drain. we washed several empty cycles since with no results
You will have to take the hoses off between the tub and pump, and the pump and weall drain. They are packed with rubber. Oh, don't forget to clean the inside of the pump too. Run clean water through all hoses and the pump before reinstalling and you should be fine. Don't wash rubber backed rugs in washers unless you go to the laundry mat. This should be put in the maintenance guide of your washer book, but I've yet to see it.
Feb 03, 2010 | Malber P21 Front Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore Elite HE3 washer- 1 year old
Have you followed all the instructions on this link?:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If all you have checked is the drain hose, you need to check the drain pump reservoir and the drain hose PRIOR to the pump (coming from the bottom of the wash tub). Rugs are notorious for collecting and holding large amounts of dirt. This dirt will pack together in the drain lines and pump and clog it up. I hope I'm not too late with this post. I was hoping to save you some money. Let me know if the helps.
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
GE WBSR3140DW Top Load Washer Logo
118 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
