Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool oven will not heat up after self lean
I have a Whirlpool RBS275PDB16 oven and was in the middle self clean cycle when we had a power failure. Eight hours later the power is on and the control panel is lit on the oven but the oven will not heat.
  • Whirlpool Master
  • 3,361 Answers
Check the overload thermostat inside the back panel of the oven.
No continuity? Replace it.
Posted on Mar 11, 2009
Self cleaning oven model #wfc150moewo how to set
Hello, Diane -
Are you asking about the Whirlpool model WFC150m0ew? I do not find information on any model with the number WFC150moewo.
If you mean the Whirlpool model WFC150m0ew and you do not have the owner's manual to read about the self-cleaning settings, I have located the owner's manual for that model on the Whirlpool website.
See:
https://www.whirlpool.com/results.html?term=WFC150M0EW&showTab=modelContent
Look for the 2 links to download the Use & Care guide. The self-cleaning instructions are on Page 11 of version of the Use & Care guide - whichever one you choose to download and save.
By the way, when you download and then save the Use & Care guide, so you can print it for easy reference, be sure to give the file a name you can find easily in your Documents folder - something like: Whirlpool Oven Manual.
Best wishes.
Jan 16, 2018 | Ovens
Aqua lift doesn't clean the oven.what should I use or do.
Spray with Easy Off. Put a glass dish of cleaning ammonia in the middle of the oven. Leave overnight. The next day everything will rinse off. Have plenty of ventilation and wear long gloves.
Maytag AquaLift Self-Clean Technology - YouTube
2q==? 1:55 https://www.youtube.com/watch?v=LdBzf6DHyHI
  1. Similar
Mar 23, 2012 - Uploaded by The Home Depot Watch Associate Joey demonstrate Maytag's AquaLift self-clean technology. If you'd like an oven that ...
AquaLift self-clean oven technology - YouTube
9k=? 1:09 https://www.youtube.com/watch?v=4mdiD1yid1Y
  1. Similar
Jan 6, 2012 - Uploaded by Whirlpool Corporation Whirlpool Corporation is introducing AquaLift™ self-clean technology, a first of its kind cleaning solution to self ...
AquaLift TM Technology Cleaning Methodology - YouTube
z? 3:48 https://www.youtube.com/watch?v=zfKLpQdZD5c
  1. Similar
Feb 3, 2012 - Uploaded by Whirlpool Appliance Repair Self Help Videos AquaLift TM Technology Cleaning Cycle & Cleaning Methods.
Whirlpool® Cooking - AquaLift™ Self-Cleaning Technology - YouTube
z? 0:21 https://www.youtube.com/watch?v=N1-Gty3LUik Mar 6, 2014 - Uploaded by WP Canada Now it takes minutes, not hours, to get a great clean that's odour free with Whirlpool® AquaLift™ Self-Cleaning ...
Aqualift really does work - YouTube
2q==? 2:33 https://www.youtube.com/watch?v=5GRImKNE3BA
  1. Similar
Aug 20, 2012 - Uploaded by apreston123 This video shows the aqualift self clean in action. Video starts after the 40 minute cleaning cycle has finished ...
Jan 10, 2018 | Ovens
Power Failure while oven was in self cleaning mode. When power was restored the control panel is completely dark, no error codes or PF indicator. The oven door is also locked after 24 hours, so the the...
Hello. You have an open rear oven thermostat causing the complete power failure of your unit. The part numbers you need are W10176670 for the upgraded blower and 9759243 for the thermostat. You will have to remove the oven from the wall in order to remove the back covers to access the thermostat and blower. The blower has been upgraded from 950cfm of airflow to 1200cfm. I have performed this service flash--you will definitely need a helper or 2 in order to pull the oven out and work on it. There is a service bulletin on your oven describing this exact situation. When you replace the thermostat and blower, re-mount the oven and then restore power, the oven will function and unlock. The link for the thermostat is here:
Thermal Overload Safety Thermostat
The link for the blower is here:
http://www.appliancepartspros.com/whirlpool-blower-w10176670-ap4369539.html
If you are hesitant about performing the repair yourself, definitely call for service. I hope this helps you!
Nov 06, 2015 | Whirlpool RBS305PRS Stainless Steel Oven
My electric Whirlpool oven won't heat after doing a self-cleaning.
It's possible the heating element burned in half while doing the self clean, it has to stay on a long time for the self clean cycle, try unplugging and plug it back in, might do it
Dec 06, 2014 | Whirlpool Ovens
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
I purchased my maytag double oven February 2011 and it has worked great. This morning I used the self clean cycle on top oven for only 2 hours. But after it cooled and unlocked I realized I needed to clean...
you might have to clean it YOURSELF....
umm, power down at circuit breaker for a minute, power up, reset clock and try again.
otherwise wait a few days.
Oct 14, 2013 | Ovens
I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
Aug 27, 2011 | Whirlpool Ovens
The panel went black- no display of clock, temp, etc. The oven doesn't heat up. the light weorks inside the oven
Hello, and sorry to read about your problem.
if you have tried to re-power the unit, and still have the same issue, you then have a general main board failure,
you may want to contact a service company. it takes experience to know which part is defective.
I tried to help you. Please help me and vote/rate my response thanks.
Jan 01, 2011 | Whirlpool RBD245PD Electric Double Oven
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Whirlpool RBS275PD Electric Single Oven Logo
591 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
