Question about Zenith ZPA-314 Portable DVD Player
How do you change the lens on DVD player. Where can you order the part? The screen is blank when I put in the disc.
How can i change the lense of a dvd
Posted on Aug 31, 2009
Trying to record to disc from VHS After recirding 8 copies, it now reads "Unknown disc, Please check disc" This is a Go-Video VR3845 Unit.
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
Can't record DVD's
Hello there.
As per http://www.videohelp.com/dvdrecorders/cinevision-rv4000/881
you can see that your DVD player only supports writing to DVD+R
or DVD+RW, not DVD-RW or DVD-R.
Hope this helps.
May 24, 2008 | GoVideo Cinevision RV4000
Trying to copy VHS to Disc-Says"Unknown disc"
No Disc
I had this identical problem just after a year and a half of use. I tried cleaning the lens... that didn't change anything. I tried using movie discs that I knew had worked before.... same problem. I took the unit apart and found the problem. There 5 or 6 (I forgot exactly) capacitors on the power board that are black cylinder types with silver tops. If the tops look like they are bulging, then It requires changing capacitors on the power board. I ordered them through the internet, removed the old and installed the new capacitors. Now everything works great.
The capacitors are: 10v 2200uf 105-Degree Capacitors. They cost about 20 cents a piece.
Good luck.
Nov 12, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD won't read discs
try cleaning thelens inside the unit.use a clean cotton ball to wipe the surface of the lens.DONOT USE ANY LIQUID!! extra care..
Sep 12, 2006 | JVC HR-XVC33U DVD Player/VCR
Zenith ZPA-314 Portable DVD Player Logo
1,329 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
