Question about Pioneer Car Audio & Video
RCA ports on back of a Pioneer cd player
I got a Pioneer cd player with 4 RCA ports an i need to find out which one is a used for a 2 channel so i can bridge my subs to my amp because i need to run two RCA cable to the amp from the cd player an i have tried everyway an it just over loads the amp everytime
  • 33 Answers
Well you should have two sets, front and rear. Either of those sets can be used to go to the amp and it should work fine bridged. If your problem still exists then either you are getting a bad signal form the RCA outputs on the deck or have anouther problem somewhere in the system like in the amp or amp connections. What exactly does the amp do?
Posted on Mar 02, 2009
How do i assemble a pinoeer stereo system model VSX-504s and model CLD M403
Use RCA audio cables to connect the CD player to the receiver. The CD player should have two RCA jacks labeled "audio out"; On the top row one jack is red and the other white. On the Pioneer receiver in the back, there's several rows of RCA jacks. On the bottom , just to the right of "tape monitor"it is labeled "CD". Plug the red RCA cable into the red jack on the bottom and the white plug into the white jack on top of the red jack. On the front panel of the pioneer receiver is a small button labeled "CD". Press that button to listen to the CD's.
images?q=tbn:and9gcrfpubn4rfeo_gjllmgnn8g_iqmawgbbh3jscq6cfxrh7y-3f7qegThe red cable is fro the right channel ( right speakers), and the white is for the left.
Jun 06, 2014 | Televison & Video
I purchased a pioneer cd player for my wife's
I'm pretty sure it is referring to the rca (low level) outputs of the deck. This means you will have to use an amplifier to run a sub.
Apr 24, 2012 | Pioneer Car Audio & Video
My new pioneer cd player wont keep radio stations on mark 4 golf when i put engine off.
The problem is that when power is removed all memory is lost, the player needs to be wired correctly to retain the stations that were programmed in.
Mar 17, 2012 | Pioneer Audio Players & Recorders
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
IPOD ADAPTOR
you have to buy the ipod connection kit to pioneer, but if your deck have RCA input at the back..all you need is Y cable 2 (RCA male - 35mm jack)
RCA will be connected to DECK, 35 mm jack to your ipod.
to use your ipod...change the input setting on your deck to AUX (auxillary) most deck have this for CD Changer connection
Good Luck
Mar 13, 2009 | Pioneer DEH-P6700MP CD Player
My subwoofers will not play
go into the menu screen on the pioneer unit and go to setting if you have a loud function there turn it on.... if that doesn't activate the amp ...(did you hook up the blue wire from pioneer deck to amp and run it threw the car to the amp)..if no than your pioneer deck does not realize there is an amp present in system....... if yes scroll threw menu till you see audio look for Sub Woofer or Amp you may even have a button on pioneer deck marked SW go press it and turn amp to on this will provide signal from pioneer unit to amp if this doesn't work other thing could be you hooked RCA to AUX input (but if you have a SW for RCA plugs on back of unit make sure the RCA wires are in it) the loud or SW button should activate it (if there is only F and R for RCA plugs on back of unit use R hope this helps)
Mar 04, 2009 | Pioneer AVH-P4900 Car Video Player
Connecting Pioneer DEH-2000MP to an amplifier
Hi and welcome to FixYa,
You would need a special adapter that connects to the speaker wires of the Pioneer DEH-2000MP and converts them to line level RCA ports. Something like the image below and available from here or most car stereo stores.
Good luck and thank you for using FixYa.
Jan 23, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Trying to hookup dvd
Steps to hook up DVD player:
1. Plug in DVD player
2. Plug in VIDEO cable to back of DVD player
There are multiple video out cable options: HDMI, VGA, RCA
If you aren't sure, use RCA (red, white, yellow tri-plug cable) and plug yellow into VIDEO OUT port.
3. Plug other end of video cable into TV's VIDEO IN port.
4. Turn on TV to the INPUT channel that corresponds with the input port you plugged the video cable into. Usually, this is either VIDEO1, VIDEO2, INPUT1, INPUT2, or channel 3.
May 03, 2008 | Televison & Video
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Car Audio & Video Logo
149 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
