Question about Microsoft Windows XP Professional
In c language can i print my name without using semicolons???
I want to print my name in turbo c++ compiler output screen in c language but the condition is in whole coding of the programme there must not b any semicolon used,,,,,,,,,can anyone help me??????
    Scholar:
  • 150 Answers
You need to use an endline function when outputting to the screen, example:
cout << "my name" << endl;
Posted on Mar 02, 2009
  • Kurtis Stalnaker
    Kurtis Stalnaker Mar 02, 2009
    This is the only method. It's very odd that you are not allowed to use a semicolon because that is one of the most important parts of the C++ language. Otherwise there is no way to end a program.
Write a program that accept a number and output its equivalent in word
Use the value that will be printed by the keyboar.
After you enter the value.
You have to cast the type you have used as integer or float into string or character type.
So here the type casting of the datatype will be used.
Oct 10, 2011 | Borland Turbo C++ 4.5 Full Version for PC
How to pprogram a java language
download java compiler from http://www.oracle.com/technetwork/java/javase/downloads/index.html
Go where you install your java, default Path is "C:\Program Files\Java"
in Java Folder open folder jdk then open bin copy its directory located at the address bar then
Right Click My Comuter > left click Properties > Advance > Environment Variables > on System Variables find Path then click it then click Edit
insert a semicolon " ; " on the end of the textbox (if already have don't add semicolon) then paste the directory you copy...
you can now create your Java Code....
to Compile and Run it...
open command promt ( to open click start > run > type cmd )
go to directory where you save your java code..
(ex. if your Directory is "D:\Java Folder" then type "cd.." press Enter repeat "cd.." until "C:\>" is remaining then type "D:" press enter then type "cd Java Folder" then press Enter type "javac (name of your javacode).java " Press Enter (if there is an error correct your java code) if no type "java (name of your javacode)" there you can run your Java Code
Aug 04, 2011 | Microsoft Windows XP Professional for PC
I want to transfer a program written in c++ language in microsoft word to turbo c++ what I have to do?
You have to copy and paste the program in new file in turbo c++.Compile it and correct errors and run it.
Nov 30, 2010 | Borland Turbo C++ Suite 1.0...
I have a windows 7 or windows xp both in one computer . when i am install turbo C soft ware in window 7 it doesent open full screen in window 7
turbo c will not open in full screen on windows 7 neither graphics will work
so either u have to use dos box and mount turbo c on it or use some other compiler
Nov 20, 2010 | Computers & Internet
Please write a java program to print my full name dhanalakshmi in a single line.
place the below code in a text file dhana.txt and compile it.
class dhana {
public static void main(String[] args) {
System.out.println("dhanalakshmi"); // Display the string.
regards
harit
Jul 07, 2010 | Sun Java Programming Language (cdj-275)
How to write a c progaram without using semicolon
The semi colon is a required element. C and C++ will not work without them. Depending on your compiler you may be able to set a compiling setting to use a different symbol to use instead of the ; but that is the default Language required end of statement symbol. Without it or something to replace it that the compiler understands there is no way for the program to know where 1 statement or command ends and the next begins.
Jun 30, 2010 | Computers & Internet
HOW TO RUN TURBO C IN 64 BIT WINDOWS 7
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window 7 will no longer run 16 bit applications and this includes Turbo C 2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making these programs nearly two decades old. They are just too old to run on modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit programs which no long run on many modern computers. So the best advice is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
  • Microsoft Express 2008 -- Great compiler and comes with a nice IDE (Visual Studio)
  • MinGW -- Command line compiler but there are many IDEs that use it such as Code::Blocks, Eclipse, Dev-C++
  • Borland C++ 5.5 -- Will compile Turbo C++ programs (including graphics.h) but produces 32bit code (slightly better than Turbo C) Only includes command line tools.
  • DigitalMars -- Its still old but at least it produces 32bit programs (better than Turbo C). You might stumble across D++ which is a very powerful language derivative of C++.
  • OpenWacom -- Again, nearly as old as Turbo C, but it produces more modern 32bit applications! (this project is still active too).
If you are just working with C there is:
  • Pelles -- and excellent modern C compiler and IDE. Pelles also has the new TR1 libraries available so you can use regex and other new features. As well as support for many older libraries.
  • LCC-Win32 -- Used as the basis for many of the research compilers.
  • Tiny C -- is said to produce very fast programs.
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
Regards.
May 24, 2010 | Microsoft Windows Vista Ultimate Edition
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
What is a compiler and ite story
A compiler takes code that you have writin, and 'compiles' it into machine language code ex.10010011, a language that your computer can understand and execute.
Jan 15, 2009 | Computers & Internet
Looking for a vista compatible c/c++ compiler
As 32 bit vista does not support full screen 16 bit plarforms(like c/c++) nd not at all suportable by 64 bit vista. to install u have to install the display drivers of XP, that can be found at the site of the manufacturer of ur Laptop/PC(in some cases graphics card manufacturer). All the best...., further having any query , pLz fell free 2 ask
Mar 05, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
