Question about LG Televison & Video
ON LOADING THE DVD, THE DISC TRAY CLOSES BUT THE DVD FAILS TO PLAY AND THE LOAD CAPTION REMAINS ON.
    Scholar:
  • 85 Answers
Its the problem of lens but many a times resetting works. but if you have ----C ----- BUTTON IN YOUR REMOTE JUST KEEP IT PRESSED FOR couple of minutes with unit on.and remote pointing towards it.
Posted on Mar 02, 2009
Kenwood CD/DVD player moder DV-605 tray is jammed, how can I manually resease it
you have to play the disc in another player or you can change the type of the disc.. the player is just not compatible with your disc.
Dec 08, 2012 | managemylife.com
The disc tray of my philips cdc wont change when i press the load button
Either the loadimg belt, or the gear wheels might have the fault. Replace the loading belt first, if your are handy.
May 10, 2012 | Televison & Video
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
I put the disc in and then it closes and then opens again and i close it and it opens again. does it need to be cleaned or what?
itis unable to load the disc from tray to the spinning mechanism for playing or recording take it to the repairs there is an assembly problem or loading mechanism problem
Feb 20, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Internal DVD
hi if your dvd driving belt is slack, it wouldnt be able to draw the door to a position where it will press the loading switch, so it will eject back. 2. if your dvd laser lens is dull or too dirty or dead it might be making attempts to load severally.if the disc driving motor is bad, the tray can be open & close many time without a success
May 24, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Drawer closes by itself
The loading mechanism is off by a tooth or 2. The tray out position switch is not being triggered properly and the tray will reenter the machine. Did this just start happening? It is possible that the sensor switches are defective too. Worse case scenerio is about $5 in parts plus the local labor rate for repair.
Dan
Mar 28, 2008 | Pioneer HTD-520DV System
LOADING
It is pretty common problem.
If all of your DVDs are having same problems,
it is most likely either optical sensor is at fault. The other could be the actual loading mechanism problem.
If the dvd tray(drawer) closes all the way in but the DVD disc never completes the loading(reading) procedures, 1) it could be simply dirty or damaged disc. 2) the optical pickup device (eye) is dirty or just went defective. 3) sometimes the drawer tray that houses the DVD did not complete to engage in disc reading position can produce this result.
I would suggest: first check the position of the drawer and condition(s) of your DVD disc itself.
If the pickup device(optical eye) is dirty or defective, that needs to be serviced by a qualified technician. or contact JVC service center. Their information can be found at
http://support.jvc.com/consumer/support/support.jsp?pageID=10
Feb 13, 2008 | JVC DR-MV1SU DVD Recorder/VCR
PANASONIC dmr-es10
The DVD RAM drive is mis-aligned and does not load the disc correctly.
contact our local service center for a quote
Dec 14, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
Computer Repairing
Computer Repairing
