Question about SanDisk Sansa Clip MP3 Player
Help with Sansa clip?
My Sansa Clip won't charge from my computer, it just shows a black screen with no activity. I have tried all the USB plug in's on my computer and none of them work? Is it my computer or Clip?
  • lona734 Mar 07, 2009
    I have the same problem, I have a had it for about a year. Sucks, I will have to buy a new one, I thing I will look into the Ipod
  • 8,596 Answers
Make sure the hold/lock switch is not engaged first.
If it is not, you can suspect either hardware failure or a bad USB cable. Either way, call Sandisk and determine if you are still in-warranty. They can order replacement USB cables if they are still available.
-Tha Mp3 Doctor
Posted on Mar 04, 2009
Sansa clip sandisk 2gb won't charge. Thought it was low and after plugging it in to computer overnight it wasn't fully charged but worked the next morning but suddenly died. Now it won't charge. Sansa...
I had the same problem this morning, albeit with my 8G Clip. Nothing worked -- the thing seemed dead as roadkill -- until I found a link about "forcing MSC mode." Basically, it told me to hold down the center button while plugging my Clip into my computer using my USB cable. Suddenly, boom! It's awake and alive and happy again. I'm unsure how that works, but that did it for me.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk 2GB Sansa clip will not charge with USB.
The problem maybe the usb cord or it maybe the hardrive in the monitor hooked up to the network drive. If this doesent help i will try to help as much as possible.
May 22, 2009 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk Sansa Clip 2GB not detected by XP SP2
Change the USB Mode to auto-detect and see if you get better results. If that fails, switch entirely to MTP mode.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa Clip MP3 Player
Can't get sansa clip to turn on or charge
i have found that using my playstation 2 unit or direct tv box (only if you HD) will charge it try that good luck
Jan 13, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Brand new Sansa Clip not recognized in My Computer
Hello!!
try connecting it to other USB slots!!
Nov 04, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip does not show up on computer
I had the same problem all you've got to do is first turn on the sansa clip.Then go to settings. After that scroll down to USB mode (second from bottom) then it woul probably say auto detect. Scroll down to MSC then hit enter. If that doesn't work try MTP mode.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
Ask about my sansa clip
does it come with anything else like a cd or usb clip with the software?
Apr 28, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
239 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
