Question about Xerox WorkCentre XL2130f Laser Printer
L 6 code flashing
L6 code flashing on Work Centre
    President:
  • 2,072 Answers
That is a laser fault. Normally the motor that turns the mirrors in the laser assembly is failing.
You can also try this. take the back off the machine, there is a ribbon cable attached to the main board that I have seen unplugging and re connecting resolves an L6.
about the best price I have seen on that laser is about $300.
Google a business called "the parts drop". You can look up the part and price there. Honestly, that is one heck of a job replacing that laser. You pretty much have to split the machine in half to replace it.
Posted on Mar 02, 2009
Phone security password locked
the default normally is 000000 ( security code) and user code is 1234. if not helpful, post back for more solutions.
Dec 22, 2010 | Motorola Mobility L6 Cellular Phone
Cant send out sms but i can receive on motorola L6
HEY HI...
THIS IS NOT A BIG PROBLEM...JUST GO TO YOUR MESSAGE SETTINGS AND CHANGE THE MESSAGE CENTRE NUMBER...IF YOU DONT FIND ANY DEFAULT NUMBER,JUST RING THE CUSTOMER CARE SUPPORT AND ASK THEM THE MESSAGE CENTRE NUMBER,ERASE THE OLD ONE AND KEEP THIS NUMBER SAVED...SWITCH OFF MOBILE AND TRY,YOUR PROBLEM WILL BE SOLVED.... THANK YOU....GOOD DAY
Sep 22, 2010 | Motorola Mobility L6 Cellular Phone
How to unlock a motorola cellphone that comes from venezuela.How can I unlock it so it would work here?
yes.... there is free unlock code for your Motorola L6.... i am a usertoo of Motorola L6 and i juz figured out how i can get the unlock codefor my Motorola L6.... you can do it all by youself!!!! juz follow this:
1)form your Motorola L6 idle mode, press d menu key (menu key is d keybetween the left and right soft keys) and go to Settings>Security> New Passwords> then change unlock code;
2) as you sEe, Ur phone is asking for Ur old unlock code, press the menu key to switch it to security code;
3)as U press the menu key, U will notice that Ur phone is now asking forUr Security code.... enter Ur security code (the default Security codefor Ur Motorola L6 is six zeros<e.g. 000000>) then press<OK>
4) now, Ur phone is asking for New Unlock Code, type d code U want (max. of 4 chars.) then press <OK>
5) enter again d Unlock code for verification....
TIP:if U forgot Ur Unlock code again, juz do d process again. u canforget Ur unlock code but never forget Ur security code!!!! you canswitch the unlock code into security code by pressing the menu key!!!!
is that thing solve Ur problem???? pay me back by sending me Ur coMment: phreanz_44@yahoo.com
this solution is for Motorola L6.... try this to Ur Motorola phone and see if this work!!!!
Sep 30, 2009 | Motorola Mobility L6 Cellular Phone
Forgot my lock code ..motorola phone ,please help
Sir, try to enter the security code instead of the lock code. It will unlock it. Its default is in the manual. If it doesn't work, go to a Service Centre. They will update the phone and make its features and the code to default. Now you have to enter only the default code. Thank you Sir, Have a nice day.
Sep 20, 2009 | Motorola Mobility L6 Cellular Phone
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
I have a sharp ar-m160
if you press the print switch while the l6 code is in the window you will get a second code. more than likly it will be a 10 that means your laser unit is bad & needs to be replaced.
Nov 12, 2008 | Office Equipment & Supplies
Battery chargeing not sufficient
its time to replace your battery
no service centre required.
Oct 29, 2008 | Motorola Mobility L6 Cellular Phone
DAMAGED L6
Ya do a testpoint flash and ure done
Oct 08, 2008 | Motorola Mobility L6 Cellular Phone
My Thermostat is flashing "L6"
The battery needs replacing.
Aug 28, 2008 | Heating & Cooling
Xerox WorkCentre XL2130f Laser Printer Logo
257 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
