Question about Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System
Top freezer not freezing ice
I have a Frigidaire top door freezer model # Frt21nnc 21.0cu ft the compressor is working the tope freezer fan is working but is not able to make ice or keep to bottom part of the refrigerator cool. I have unplug it for at least 24 hour to make sure all or any ice build up meats. I have clean the coil off I have pull the back panel wall of the freezer of to make sure no ice build up on coils. Reading some of the suggeston on the other problem people had could it be my relay problem or termostat if so on my compressor is thats were my relay is located. Can you please seed me a picture were it is located( relay & termastate) I could sure use some assistance with this problem can not afford a new refrigator
  • 400 Answers
It sounds like your defrost element is faulty, this is located on the freezer coil, there is also a defrost limiting thermodisc which must also be replaced at the same time.
Posted on Mar 05, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
My ffus2613lp doesn't seem to be circulating the cold air. It's alarm went off yesterday and the ice began melting. I took everything out of the freezer and unplugged it, pulled it out, cleaned...
it sounds like the evaporator fan isn't working,when you open the freezer door you should hear the fan running in the freezer,if not bad fan motor,part number 242077701 and it's around 75 dollars
go here and you can look up parts at sears
Jun 17, 2014 | Frigidaire Refrigerators
Stopped cooling
My refrgerator a Kenmore, model 106-71182101, with ice maker stopped cooling and freezing.I vacuumed the condenser coils, and
fan in the rear bottom, along with any other debris. I unplugged the frig because the compressor was very HOT!.Question? Could the compressor have a Locked-Rotor? If so what can I do to loosen it.
Apr 08, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
Coils frozeup and iced on top shelf of freezer---did a defrost--when shut the door don't hear the shhhh sound-nothing blocking it and seal is good--light is on but won't freeze any food--threw out alot! ...
Defrost the unit totally so you can see no more ice, may take a day or more with door open, once done, restart the unit, check you can hear the fan running in the freezer, if not, replace fan unit, if you can hear it, the defrost timmer may have failed or the defrost element has gone. If the unit appears to work correctly, dont be fooled, the problem will return, if the unit does not work as it should, regas is required. Hope that helps.
Dont forget to vote for the solution, thankyou
Mar 04, 2011 | Frigidaire 13.7 cu. ft. / 388 liter...
In the house we just bought there is a copper brown top freezer Frigidaire which says it is a Deluxe 17. Cleaned it and plugged it in. Set freezer unit for "normal:" and refrigerator on...
Freezers only buils up layers of ice after multiple opebing and closing of doors allows fresh air inside, the moisture then freezes out of the air and builds up in layers on the cold surfaces. Note that the more ice that builds up decreases the efectivness of the freezr and thus costs more to run. To test try making ice cubes in atray. The number 1 setting on the fridge will be the warmest setting. Hope this helps.
Sep 29, 2017 | Frigidaire 16.5 Cu. Ft. Top-Mount...
Kenmore 18 top freezer doesnt freeze completely. refigerator cools to 48 f .
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Frigidaire Upright not cooling
Not enough information but  if you are refering to the compressor as the black housing below, it seems that the compressor is either seized or burnt out.
Oct 25, 2007 | Frigidaire 11.6 cu. ft. / 328 liter...
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System Logo
288 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
