It sounds like you have a bad seal or O-ring. without takeing it apart and looking at it myself i cant tell you witch one is bad.if take it apart look the orings and seals over reall well and se if you can find any distorted places on them and then you can find a breakdown of the nailer and buy the seals or O-rings on this site.http://www.ereplacementparts.com/
The non-marring bumper for the ET200 nail gun is Part #2815. Send a note together with a check for $1.50 plus $1.00 S&H to Parts/Service Dept., Arrow Fastener Co., 271 Mayhill St., Saddle Brook, NJ 07663.
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
You might get better penetration if you use your other hand to press the gun down firmly onto the surface before you pull the trigger. (This will help if the gun tends to jump a little when you fire it.) Or, if the surface you are firing into might not be rigid enough (like a thin board that is not supported) - in that case you might improve the penetration by better supporting the surface you are nailing into, perhaps by placing it on the floor. On the other hand, this may simply be a case that the gun is not powerful enough to do what you want it to do. To test that theory, try it into a piece of soft wood (like a 2X4) or find a soft thick material as a first layer over the wood you are using. Perhaps you can use shorter nails - thin brads in wood don't gain much strength beyond 1/2 inch penetration anyway. The length of the brad only needs to be about 1/2 inch longer than the thickness of the first layer of material.
I hope this helps,
good luck
Al K
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
