Question about Avanti Refrigerators
Avanti wine cooler temperature problem
I have Avanti wine cooler, model # WCR683DZD, 2 separate temperature controlled for white/red wines. Temperature doesn't work and leaking water becomes ice from the compressor (inside of cellar). Still it's running and I don't want to stop the cooler completely. I cannot find any repair service. They said it's different from regular refrigerator repair. Thanks for your help in advance!
  • Anonymous Mar 18, 2014
    my fridge keeps going beyond the selected temperature
    Scholar:
  • 85 Answers
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
What kind of cooler should I get if I plan on storing both red and white wines in the same fridge?
You need a dual zone wine cooler. They have two temperature controls and the storage space is divided in such a way that each temperature control has its own section inside the cooler; allowing you to store both red and white wines properly.
Jul 31, 2012 | Furniture
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
No power, lights or anything
This is easy. It's the power supply problem. I bet you there is no juice coming out of the same electrical plug. So fix the plug or reset the circuit breaker.
Jul 31, 2009 | Avanti WCR683DZD Stainless Steel Wine...
AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Jun 04, 2009 | Avanti WCR683DZD Stainless Steel Wine...
2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
I want the bottom to be reds and top to be whites
I don't think you'll be able to do this without some modifications to the unit.  The wine cooler is designed to blow cold air into the bottom section, and the top section cools down by spillover of cool air flowing between the glass door and the temperature control panel.
I guess if you could figure out a way to turn the panel that separates the top from the bottom you could make it work.  You'd have to switch the temperature sensing leads on the thermostat inside that panel(that would be pretty easy) and you'd probably want to flip the LED indicators so they read right-side-up.  The main issue would be that the screw holes for mounting that separator panel are all on the bottom, but when you flipped it, they would be on top with no holes in the walls to screw them into.  If you are willing to do that, you might be able to make it work as you would like.
Good Luck!
Dec 27, 2007 | Danby DWC283BLS Wine Cooler
Refrigerators Logo
1,385 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
