Question about Bosch AquaStar 2400ES-NG
BOSCH TWH-G1-25 not lighting
When i turn the water on, the heater starts clicking (assuming that is the auto ignition trying to come on??) but the burners don't light. the water pressure hasn't changed between the time when it was working and then wasn't . . .
thanks
On my bosh250 hot water won't turn on. Shows A2 code I hit restart several times then as long as the hot water is on it will stay hot but when the water cools down the A2 code is back. Help!
Posted on Dec 18, 2011
  • 50 Answers
Model????? The 635Es, 250SX and 2400E are same. The 2400ES and 2700ES are World 2 heaters. Any error codes as I can't imagine this problem w/o codes. Flow initiated but you have spark. Is there any ignition? If so flame rod may be bad and not reporting ignition. Igniter sets on some early 2400/2700 have proved to be bad. Water pressure has zero to do with this. If you have an EC or EA code you have gas problems (meter, line size/length or gas valve). Also if 3005 or 3007 Software you can pull the last 5-10 error codes from Controller.
You need to call Bosch and get an RSA out there. This is a gas appliance that if you screw up can destroy your house. FYI any water in the gas valve condemns it. It will not dry out and work correctly. Is the fan running at ignition and/or purge? Any Controller errors require replacement. You have 2 years on parts warranty from installation date so don't screw around trying to DIY. Warranty Labor is not covered.
Flue obstruction? If you used the AQ3 installation Kit you have the wrong termination box to prevent freeze up and/or water penetration You need the Z-Vent drop nosed termination. Look for a fine tan dust in the fan intake (brown plastic) the intake throat or in passageway to the gas valve. Call Bosch unless you're a Gas Tech this is beyond you.
Posted on Mar 03, 2009
Black soot on outside wall above hot air exhaust. Excess flame, incomplete combustion? How to adjust/correct?
All gas water heaters, tankless and tank-type, require cleaning burner and combustion parts.
Tankless manuals suggest once per year.
Tank-type once every 2-3 years.
Before calling service technician, open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/TWH-G1-13_Removing_and_cleaning_burners.pdf
Burners do not operate cleanly:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125BOTechSupport/Troubleshoot/tabid/602/Default.aspx
Jun 26, 2011 | Bosch 125BO NG AquaStar Outdoor Natural...
Pilot light not staying lit
Before calling service technician, open following links for Bosch Tankless resources:
The problem may be as simple as needing to catching up on pilot maintenance.
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-24_Removing_cleaning_and_replacing_standing_pilot.pdf
Other problems can include low gas pressure, faulty sensor, faulty gas valve, tripped ECO/ safety circuit, safety circuit connections need cleaning.
Add a comment and say what you did to fix problem to help others with same problem.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Bosch AQ125BO LP AquaStar 4.3 GPM Outdoor...
Failing ignition on Bosch Aquastar AQ125-HX tankless on demand water heater. Carefully followed all directions on device to best of ability. Gas supply is full and on. Water pressure should be...
Resources at Bosch
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/tabid/370/Default.aspx
Typical Bosch Aquastar manual:
http://waterheatertimer.org/pdf/Bosch-aquastar-170vp-manual.pdf
All tankless and tank-type gas water heaters require regular cleaning and maintenance.
It is unknown if your unit needs maintenance or repair parts, but catching up on maintenance using information from manual is good place to start.
Gas appliances are increasingly complicated and experienced technician is good resource to have in local area before installing tankless.
Apr 16, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a bosch aqvastar 250 sx ng error code EC keeps appearing
Q. EC - Ionization failure during operation
A.
  1. Verify gas type (See Fig. 2 in installation manual) corresponds with the type of gas supplied to the heater.
  2. Verify the three yellow wire connections to the set of electrodes (underside of the burner assembly) are secure.
  3. Verify that venting meets specifications per chapter 3.6 of the installation manual. Improper venting may cause premature failure of the flame sensor rod.
  4. Check gas pressure. See Bulletin TWH-G2-03.
  5. Check and adjust CO2 readings. See Bulletin TWH-G2-12.
  6. Gas valve or flame sensor may be damaged. Call Bosch Water Heating with observations and results of previous steps.
Mar 06, 2011 | Bosch & Tankless LP Hot Water Heater
My halstead hero 50 lights but keeps sparking then goes to lockout ? please help
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-08_Pilot_flame_no_burner_flame_troubleshooting.pdf
This is information from Bosch regarding the identical problem. You can use this for general information, but if you can't make this type of repair, call a service company.
Gary
Dec 15, 2010 | Water Heaters
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
Aug 06, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Bosch AquaStar 2400ES-NG  Logo
482 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
