Question about Coleman Powermate Powermate 5000W Generator
HAVE A TROY-BILT 8000 WATT THAT STILLS RUNS GOOD, BUT NO OUT PUT.
MOTOR RUNS GREAT, BUT NO ELECTRIC. WON'T EVEN LIGHT A LIGHT BULB. PLEASE DIAGNOSE AND TELL ME HOW FLASH.
THANKS.....................BILL
  • Gregg Apr 09, 2009
    The same problem, did you find any help?
Visit this site http://www.perr.com/phpBB3/ and they can tell you how to flash your generator. Might I suggest you run the generator often and put it under load even if you're not depending on its power output at the time like you would in a power outage. Like use it to power a shopvac or similar device.
Posted on Mar 21, 2009
  • barbbragg Nov 26, 2010
    We have the same problem with ours. It loses it's polarity. Start the generator, plug a drill into it. Hold the trigger on on the drill and twist the drill head backwards a few times until it starts. This usually does the trick.
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Replaced fuel lines on my troy-bilt tiller and it ran great came back the next day gas in the lines and bulb was empty realized the bulb was cracked , i replaced the primer bulb and put everything bac
By the absence of the gas in the lines Sounds like the small hoses are cracked also, best to replace them..they do get brittle over time..best to change them periodicly... It can be a DIY job may have to loosen the carb to bend and get them on.a .very inexpensive part..and be bought at any shop or auto parts store..and not a big job for the repair shop..good luck
Sep 23, 2014 | Troy-Bilt Garden
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
Troy Bilt 8000 watt generator is not puting out full 120 Volts after converting to run on propane.
if the rpm's are not right the voltage regulator can't put out more than its putting out
May 28, 2012 | Garden
I need a manuel or starting instructions for a 8000 Watt Troy Bilt generator.( Model number 65157/30247. This is an electirc or manuel start.
See this webpage for manual:
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/030247-0/Troy-Bilt%20Portable%20Generator%20Operators%20Manual/030247_0esCw/
Feb 19, 2011 | Garden
My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Jun 20, 2009 | Electrical Supplies
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troybuilt cultivator/edger won't start
There are two starting procedures - initial starting after long storage or running out of gas calls for squeezing the bulb (note - squeezing the sides together - not pressing the bulb in) 6 times, poulling cord up to 10 tiimes, rapid pull. If that doesn;'t work, wait 15 minutes, do not press bulb, but pull cord 10 times again.
Normal starting after first use and w/gas in the tank calls for 2 presses of the bulb.
I found that I was not priming the engine well, but also it should not be as much of a pain as it is. I still am successful in starting on every third attempted use, get frustrated and say %*&% it most of the time. These things are made by MTD (for Troy-Bilt) and that, in my experience, stands for Machine Typically Dead.
Hope this helps.
Apr 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Coleman Powermate Powermate 5000W Generator Logo
2,144 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
