SOURCE: I locked myself out of my RCA 27F520T 27inch Tru
Hello
If you did forget the passcode to your RCA Tv, you can reset it. Simoultaneously press "VOL+" on the remote control, and "CH+" button on the front of the tV. The display will appear for you to enter your new password.
SOURCE: I accidently turn on the
You can purchase a remote control from Partstore.
http://www.partstorecanada.ca/Part/Thomson/RCA/27F520TYX1/Thomson/RCA/265714/New.aspx
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these. 1.
Hold down the
MENU button on the remote and VOLUME DOWN button on the TV it's self at the
same time for at least 4 seconds. The set won't say so, but the lock will be
unlocked 2.
Hold down the 0
(zero) button on the remote and the VOLUME DOWN button on the TV itself at the
unlocked 3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU
button on the front of the TV at the same time for at least 4 seconds.
Most RCA sets use a
four digit code to control the v-chip. The code reset is different depending on
the model. Try each number until you find the one that works for you.
Hold down EJECT button
on the front of the TV set and the MENU button on the remote at the same time
for at least 4 seconds. Depending on the model, one of the methods should
unlock the V-chip. Now, if desired, you can change the settings on the V-chip
by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to
MENU and then going to TV SETUP, then to V-CHIP SET.
SOURCE: my rca truflat tv is stuck on fpa lock mode and I don't have the remote. How can I unlock it?
Most RCA and GE TV
sets use a four digit code to control the v-chip. The code reset procedure is
different depending on the model. Try each method until you find one that
works: 1.
Hold down MENU
on the remote and VOLUME DOWN on the TV it's self at the same time for at least
4 seconds. The set won't say so, but the lock will be unlocked 2.
Hold down the 0
on the remote and the VOLUME DOWN buttons on the TV its self at the same time
for at least 4 seconds. The set won't say so, but the lock will be unlocked 3.
Hold down the
time for at least 4 seconds. 4.
Hold down GO
BACK on the remote and MENU on the front of the TV at the same time for at
least 4 seconds. 5.
Hold down EJECT
on the front of the TV and the MENU button on the remote at the same time for
at least 4 seconds.
Depending on the
model, one of the methods should unlock the V-chip. Now, if desired, you can change
the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS,
or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
1.
Hold down the
unlocked
2.
Hold down the 0
unlocked
3.
Hold down the
1.
Hold down MENU
2.
Hold down the 0
3.
Hold down the
4.
Hold down GO
least 4 seconds.
5.
Hold down EJECT
at least 4 seconds.
Depending on the
