Question about LG DLE2512W Electric Dryer
LG dryer DLE2512W power up but won't run when press start button.
My LG dryer model number is LG DLE2512W. It power up alright but when I press the start button, it sounds click-click (like a relay sound) then nothing happen. The timer is ticking down and all the lighting are operating as normal but the motor does not run. I have checked all diagnosis tests as instructed in the service manual and everything seems ok.
Please help if you know the problem is.
Thanks
  • patpsc Mar 09, 2009
    Just want to post the solution. After completely disassembled the dryer down to the motor, I did all component tests as instructed from the service manual and all passed. I narrow down to the motor and gave it a straight 110V external source and it did run ok. So, I checked the hardness terminal at the motor to see if it give the motor the power and it does not. I pulled out the terminal wire (brown) and plugged it back making sure that it has good contact and voila... the motor run as normal.
    So the problem is: electrical wire contacts getting loose due to long time motor vibration.
  • LG Master
  • 2,131 Answers
Check for broken belt. Take top off to check.
Posted on Jul 29, 2017
5 Suggested Answers
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
SearsTechToo
  • 261 Answers
Sounds like the starter winding is out.
Posted on Sep 19, 2008
  • 582 Answers
SOURCE: dryer drys drum turns , but it makes this banging
THERE ARE TWO ROLLERS ON THE FRONT OF THE DRYER THAT KEEP THE DRUM IN PLACE, IT SOUNDS TO ME LIKE ONE OF THE ROLLERS IS GOING BAD OR HAS A FLAT SPOT IF THE BANG SOUND IS CONSTANT AND STEADY THIS IS THE PROBLEM. EASY FIX YOU CAN ORDER THE ROLLERS ONLINE
Posted on Aug 10, 2009
heatman101
  • 43501 Answers
SOURCE: When pressing the start button on my LG DLE2514W
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jun 30, 2011
Lg 8377 no heat,dryer runs cold.Ran diagnostics,start more dry less dry buttons same time.Saw plc ng.
You may have a high limit switch that has failed. You will need to tear down the dryer to get access to the heating element. Look for the heating element on the bottom right side. There are 2 thermo discs located on the left side of the heating element. Test both of them. If there is no continuity, change that part.
Hope this helps.
Aug 28, 2011 | LG DLE2512W Electric Dryer
It has yellow bars and is glowing yellow when it stops
Here is a tip that I wrote about why an electric dryer will not stop heating sometimes.
Electric Dryer won't stop heating
heatman101
Aug 07, 2011 | LG DLE2512W Electric Dryer
My new lg direct drive washer just quit mid cycle, it wont start back up the code indicated power outage, but it comes on just wont run
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 04, 2010 | LG DLE2512W Electric Dryer
My Lg DLE2512W dryer works but the lights dont come on
Unfortunatley this will probably mean a new board. The lights power is fed thru the board and the chances of everyone of those little buggers blowing at the same time is very, very, small. Sorry, hope this can help.
Jan 25, 2010 | LG DLE2512W Electric Dryer
LG DLE2512W Dryer says chech filter, starts, heats and turns but makes loud noise. Maybe something stuck? A sock?
Drying drum is not on its host. Lay down the dryer and then bolt it after aligning it.
Oct 07, 2009 | LG DLE2512W Electric Dryer
Cracked Drum on LG Dryer Model #DLE2512W
If you are still looking for information on this:
No, there has not been any recall.
It is not a real common problem. I only see 1 or 2 a year, which is not many. (LE errors on washers are much more common, for example) The part number of the drum for a DLE2512W dryer is 3045EL1002D and lists for just over $100. You can find a service center to order the part from (in the US) at http://us.lgservice.com/index_b2c.jsp
I would rate the repair at about a 5 or 6 out of 10 on a scale of 1-10 in difficulty. (Basically, remove top, remove front control panel, remove front panel, remove front drum support, remove belt, drum comes out the front, reassemble.)
Dec 22, 2008 | LG DLE2512W Electric Dryer
May 23, 2007 | LG DLE2512W Electric Dryer
LG DLE2512W Electric Dryer Logo
210 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
