Question about Avaya MLX 5D Corded Phone
My customer has an 400 series Avaya PBX, we relocated the servcie demarc and reconnected incoming ground start and loop start lines. They are now experiencing a delay in extension pick ups, The hunt seems to have a delay? Any suggestions
  • Anonymous May 11, 2010
    Which system do you have? The phone listed is for a merlin legend, which does not have a 400 card.
    are you saying there is a delay in the hunt from the phone company?
The MLX phones work on Merlin Legend only. Do you have a Legend?
Posted on Sep 27, 2009
Where i can get software for mck pbxgateways
You're in the server section asking about an Avaya PBX. Have you tried contacting Avaya?
Aug 01, 2014 | Avaya Mck Pbx Gateway Unit 8 Port Switch...
How to stop all lines blinking on incoming calls-
the problem has started after a service provider change
get them back to fix or change service providers again
Jun 20, 2017 | Avaya 1416
This is a hard to describe problem, but from time to time our phone will not give us an outside line. However, when someone calls the number, the phone rings and then we have an outside line again - at...
The coils on your PBX need tuned. These coils need to be on a regular maintenance schedule
so that they are impedance-matched to the telephone company's equipment (their line cards).
The incoming call causes the telco's line card to try to adjust its impedance to your
PBX's out-of-tune coils, and you get access to outside lines for awhile, but the telco's line
card tends to return to the impedance specs that it "knows" is correct, and when that
happens, your PBX loses access to outside lines until you (or a customer) calls into the PBX
from an outside line.
Apr 17, 2011 | Lands Phones
Incoming calls ring once and are told thew will be transferred and then a voice tells them goodbye
Sounds like your system lost its programming so now the voicemail ports are just like extensions, they are ringing and picking up. And since the voicemail doesn't know where the phone systemn is, it just transfers all calls to the lowest numbered extension (10)
The system needs to be reprogrammed completely.
Jan 10, 2011 | Avaya/Partner 4-Line Display PBX...
I got the Avaya 5410 phone at home. Can I connect this peice to my landline? If so, how should I unlock it. When tried connecting the light glows but I cannot hear the ringtone.
This is a digital phone handset to use with a Avaya DIgital PBX. You will not be able to use this as a "regular" phone at your home with a tranditional phone line.
Oct 17, 2010 | Avaya 5400 Series 5410 Phone
Hi time is set on the PBX depending on the version of CM its either done on the web interface or from the command line. If you are on > CM1 there is an NTP section to add a network time protocol server IP address, the pbx will correct the timeslip with that server
see for more details
Oct 21, 2009 | Avaya Definity 8410D Phone
Mitel sx-20 trunk interrogation function codes
From a DTMF station set installed as the test line on equipment #1, go into trunk group programming (Command #66)
The SX-20 display will show programming registers.
A,B = Trunk equipment Number (1st trunk should be displayed)
C = Register 1
D = Trunk Group Membership 0 = Incoming only
1 = Group 1
2 = Group 2
3 = Group 4
4 = Group 4
E = Trunk Type 0 = Standard CO Trunk
1 = Dictation Trunk
F = Reversal Meaning 0 = Not Incoming of Disconnect
1 = Incoming Call
2 = Incoming Call or Disconnect
G = Disconnect Timing 0 = 60ms
1 = 500ms
2 = 1.5 sec
3 = 4 sec
H = Start Type 0 = Loop Start
1 = Ground Start
Move to the appropriate register using the ENTER/NEXT function (star key).
Change the data as required.
Exit programming (# key)
Hope this helps!
Mar 25, 2009 | Lands Phones
Need to reverse line 1 and 2 so that line 1 is the primary number
you could swap at the demarc(where telco responsibility ends) usually a box with screw down lugs one side marked customer the other marked phone co.
Jul 24, 2008 | GE 29439GE2 Corded Phone
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
Avaya MLX 5D Corded Phone Logo
57 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
