Question about ViewSonic Optiquest Q7b Flat panel TFT 17" Monitor
Optiquest q20wb Screen goes blank after powering off
The other day I turned the screen back on, the computer was still running, and I got my desktop for about 2 seconds then the screen goes blank. I've read previous post that were similar to this problem that stated the issue was in the power supply and the fix was to replace bulging capacitors. I pulled the power supply and found 3 - 25v 470 mF can style caps and 2 - 10v 1000mF can style cars. I replaced the 470's but this didn't solve the problem. I'm currently trying to hunt down the 1000's and see if this resolves the issue.
My question is; Has anybody had this problem on a q20wb and is someone might know if there is a possible transitor problem. How could/would I check this?
  • johnkr May 01, 2009
    I have the same problem of the screen going blank. I also took the monitor apart and found a large hole in the insulating sheet between the power supply and the metal case to which it's mounted.
    The power supply seems to be dead. Anyone know where I can get a new one?
  • 3 Answers
I had the exact same problem. The screen went black and the green light flashed. I went ahead and took the monitor apart (scary) and took a look at the power supply circuitry. I saw 6 suspicious electrolytic caps on the board. Three 470uF 25V 105 degree C caps, two 1000uF 10V 105 degree C caps, and one 470uF 10V 105 degree cap. They all appeared to be slightly bulging and one even had a small hole in the top. I decided to replace all of them. The parts cost a little more than 5 bucks. I couldn't find a 470uF 10V cap at my local store so I bought a 16 V version instead, which is fine. Anyway, after replacing all 6 caps, the monitor works as good as new.
Posted on Jul 15, 2010
I had same problem , pulled out a old mobo and stole the 470uf 10v 105 deg. c cap {is the smallest one on the power supply board} replaced and it worked fine and now i am trying to mount a exhaust fan over the area where the caps are, i noticed the most heat damage there browning of the board start with the 470uf 10v and work your way down im shure that will work=-)
Posted on Jun 06, 2009
2 Suggested Answers
SOURCE: Optiquest q20wb Screen goes blank after powering on
I'd like to report a success story. I had this same problem with my Q20WB. It sat for over a year in my garage. I eventually bought replacement capacitors, soldered them in, and now it works. You can find kits with the right capacitors preselected, or if you feel like it you can also buy them individually.
good luck
Posted on Feb 25, 2011
Optiquest q20wb LCD has black screen & green power light flashing
Hi Rickyknows2,
If you are not hearing any beep I assume you are having problem with your video so, please ...
- open your PC and check whether your video card is well placed (sometimes it looks fine but you never know) remove it and put it back.
- If you used to remove often the cable from the PC, it might be that the pins from the monitor cable are even broke... please check.
- try to find another video card and replace it just to make sure its the video ...
- last... reset the bios (but I doubt that this is your problem)
chsers ..
May 03, 2010 | ViewSonic OptiQuest Monitor
Optiquest q20wb goes to black screen after 2 secondsthen turn it off and back on stays on for about 2 seconds again goes black and if you leave it on the video will come back and then turn off almost right...
First to check will be the power supply, look for bad caps with bulging tops first then report back so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 04, 2010 | Computers & Internet
Viewsonic Optiquest Q20wb green blink light
It's an issue with the power supply, most likely the Capacitors (one or more) may be shot. Open it up if it is out of warrenty, look at the capacitors (they look like cans), if they are bulging at the top or even sides they are bad. This is a common problem with this monitor. Crappy Caps used in manufacturing. Replace all the caps with same rated caps and you should be good. Do your research on how to desolder the old ones off and proper installation of the new ones.
Aug 18, 2009 | Computers & Internet
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
I have a viewsonic optiquest monitor Q20WB and buttons not workin
Sounds like that monitor has reached the end of the road. I would recommend purchasing another monitor, other than view sonic. Purchase a Dell..they are great!
May 13, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
good luck
Mar 02, 2009 | ViewSonic OptiQuest Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Computers & Internet Logo
1,284 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
