Canon CanoScan N640P Flatbed Scanner
Problem for Canon CanoScan N640P Flatbed Scanner
Cannon n640p error
By Luisa_K - usenet poster
hi,
I don't seem to be able to use my canon n640p scanner on XP. I've tried
everything, including installing XP drivers and changing Bois settings, but
still getting "other error 0x10ff0800" message. Does anyone know how to fix
this problem?
Thanks
Shaun
Same Problem
Jul 21, 2008
-   does not work with XP
-   bubuy
Jan 23, 2008
-   I am using Windows Xp but unable to detect my scanner canoscan n640p. Pls help me to solve this problem.-   Guest
Best Solution
posted on Aug 02, 2007
Helpful)
Pasty
Rank: Apprentice
Rating: 0%, 0 votes
The error message that you have encountered indicates a communication error
between
the scanner and your PC. This is likely to be because the particular memory
address is being used by another device or program. e.g. a T.S.R. program.
Please follow the procedures below to help identify the problem:
1. Please ensure that the lock on the underside of the scanner is set to the
"Unlocked" (Open Padlock) Position.
2. Please ensure that the parallel cable you are using is the one that came
with the scanner. Please check that it is securely attached to both ports
and that it is not damaged in any way.
3. Please ensure that your parallel port is set to ECP Mode in the BIOS of
your computer.
4. Please try setting the parallel port to an alternative memory address
from within the printer port Device Manager Resources options.
5. It may be that your printer (including Canon Windows Printing System
Printers) is causing the error message. To confirm this please disable your
printer driver and then attempt to scan. To do this please go to
Start/Settings/Printers. Click on the icon of your printer, click File and
Properties. Click Details and set your port from "Lpt1" to "File" then click
on "Port Settings" and remove the check marks from both boxes. Click OK,
click Apply, click OK again. Then try scanning. If this fails to resolve the
problem we would suggest that you remove/uninstall your printer driver,
restart Windows and then try to scan.
6. If this still fails to resolve the problem you can try changing the
parallel port to (EPP ECP/EPP OR SPP depending on your operating system).
You can then try changing the parallel port address to one of the other
available options again dependant on your operating system.
7. This is a problem relating to the set up of the Pc not the scanner.
Was this helpful?
Yes
No
Solution #2
posted on Jun 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I was getting the the error massage "out of memory". I found out by change that starting the printer spooler in start>run>sercices.msc solved my problem. thats for trying.
Solution #3
Not Rated)
Kim1
Rank: Apprentice
Rating: 0%, 0 votes
Hi
None of the below, except item 6 will work. Unfotunately, Canon's
statement to use ECP with XP is a load of rubbish, as the twain
drivers are suppressed. To get your 640 working, set the parallel
mode to EPP, and it will start working OK. The scanner will pick this
up as ECP mode S
It works, trust me
Scott
Was this helpful?
Yes
No
Popular Solutions for Canon CanoScan N640P Flatbed
Questions and Unsolved Problems for Canon CanoScan N640P Flatbed
Do you recommend Canon CanoScan N640P Flatbed Scanner?
Answer
Answer
Do you have a cable for this scanner (Canoscan N640P) to connect to HP desk jet 710C printer please... (More)
Answer
We cannot scan because the window of Omnipage Pro 9 is grey.We cannot come in the window 'scan... (More)
Describe your Scanners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Scanner Experts
Top Printer Repairmen
in , MD
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
