Question about Maytag Dryers
Alantis Gas Dryer MDG7600AWW not staying hot or lit
I have an Alantis Gas Dryer Model Number MDG7600AWW. The Dryer is heating a little then nothing at all. I took the front off an can see the igniter light up, and then sometimes the flame starts and runs for awhile, then the flame cuts out, and then the igniter tries to relite the flame multiple times, but does not lite the fame. The dryer drum is running the whole time.
  • Maytag Master
  • 8,205 Answers
All you need to do is replace those pesky intermittant coils
Alantis Gas Dryer MDG7600AWW not staying hot or li - aab79a0.jpgI wote a short essay on this problem. To keep from being redundant I have it HERE
Posted on Mar 02, 2009
Maytag atlantis model #mdg7600aww how do i light pilot
This gas dryer uses automatic ignition. Their is no pilot. The gas valve assembly consists of a glowbar/ignitor, a flame detection sensor and a pair of coils all cleverly wired in a complex series circuit. When the fuse allows the control to flow power to the gas assembly all of the gas assembly components are energized. The coils cannot open the valve however as long as the ignitor is glowing. When it gets red hot it heats the bimetal inside the flame detector which shuts off the power to the ignitor. When the ignitor glows it holds open one of the gas coils. The other gas coil has enough juice for it to open, then ignition occurs. Depending on how many clothes is in the drum and how wet they are detirmins a burn period. With nothing in the drum it heats up to temp promptly and therefore the gas stays on a shorter period of time. So what can go wrong? The fuse mounted next to the control on the blower housing will melt if the blower wheel is wobbly and worn out or their is a lint build up causing air flow blockage. The control stat might be bad (doubtful) unless it ain't shutting down and is melting the fuse. If power is indeed getting to the gas assembly I would check the sensor first. if it is open circuit no power will get to the ignitor. If that is fine check the ignitor for continuity. Note: If it works a little but quits, replace them solenoid coils on the assembly. When they get aged they tend to quit when hot. My home movie of how it works:
Nov 19, 2012 | Maytag Dryers
My Maytag dryer MDG7600AWW doesn't dry at all anymore.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 25, 2011 | Maytag MDG7600AW Gas Dryer
Gas waterheater will not stay lit
if water heater heats up and after water is hot turns off you need to replace the control unit (part where all the little pipe hook into) should have an 800 number to call where you can give serial number and model number to see if still under warranty because part is as expensive as new water heater
Nov 22, 2010 | Whirlpool Water Heaters
My Maytag dryer lites then goes back out after a few seconds. It will lite again then goes out again. Model MDG7600AWW
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 21, 2010 | Maytag MDG7600AW Gas Dryer
Dryer heats on start up and then goes away model#mdg7600aww
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
dghdhg
Jul 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas burner won't stay lit
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Dryers
My Maytag Atlantis gas dryer is not heating as well
Most common problem is lint is blocking the exhaust duct. It will need to be vacuumed out.
Oct 05, 2009 | Dryers
The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
Aug 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag alantis gas dryer mdg8600awq
HI thE ELEMENT IS LOCATED AT THE FRONT RIGHT SIDE.REMOVE THE FRONT PANEL 2 SCREWS ON FRONT AT BOTTOM REMOVE PANEL THE ELEMENT RIGHT THERE ON RIGHT THANKS FOR THE QUESTION THE APPLIANCE DOC
Sep 07, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Dryers Logo
2,036 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
