Question about Whirlpool Duet GHW9150P Front Load Washer
Keeps flashing FH - Whirlpool Duet GHW9150P Front Load Washer
  • 2 more comments
  • billifisher Mar 02, 2009
    My Kenmore elite quiet pack 4 HE stopped working and keeps flashing FH I pushed pause cancel it stopped then I pushed to restart. It went for awhile then did it again.
  • Anonymous Mar 02, 2009
    "Keeps flashing FH" as well, just started this morning. Pushed cancel and restarted it again and same message keeps coming up.
    same
  • yslee Mar 23, 2009
    At about 4yrs of use for 2adults, it started giving the F/H error as well as making alot of noise when spinning. Think it will start walking soon..
    For the entire duration of owning the machine, I've used mild detergents that doesn't sud much (but it was non-HE) and used 1/2 the recommended amount which is probably about 1-1.5 tablespoon, as well as running the extra rinse cycle on at least 1/2 the loads.
    According to the A&E service person this error is due to using a non-HE detergent, it producing too much sud. He told me to run the machine w/o detergent until the visible suds are gone and to use a HE detergent afterward. Although I highly doubted that was the main source of the problem, that the errors would show up after 4yrs... I followed the instructions anyhow.
    After 2 weeks, it's again giving F/H error on the 3rd or 4th consecutive load, even when using 1/2 of the recommended amount of HE detergent.
    Scholar:
  • 135 Answers
I believe that this (FH) code is one related to water not been able to get into the machine.
It would appear to be one of the many inherent design faults on this machine.
Checked all the water valve connections accordingly and they confirm that the water connection is fully opened.
If the cold water feed is not fully opened it could cause the machine's computer to give an error.
Once opened up all the way the machine should work just fine.
Also, don't use too much soap. 1 Tablespoon even less, is enough for small amount of water. Find a soap you like, and use the extra rinse cycle when you feel the need.
Thanks for using FixYa and please rate my response. :o)
Mike.
Posted on Mar 03, 2009
Sear washer flashing fh
fh means full loud okay
Jan 24, 2013 | Sears Washing Machines
FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
My washer keeps flashing and saying FH or Hf ... what does this mean?
Check to make sure you are getting a good supply of water to the washer. Remove hoses at the washer and make sure the filter screens are not clogged.
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he3 flashing FH
The following link explains the "FH" error:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This can be a rather tough one to figure out, even with the error code explanation. I would recommend unplugging the washer for AT LEAST 30 minutes first. This will reset the Central Control Unit (CCU). In many cases this is all that is required to correct momentary glitches with the unit. If the error code reappears, check your washer installation to rule out the easiest possiblities, first. This means checking to ensure you don't have a siphoning condition, checking your drain lines and checking to ensure your fill hoses aren't kinked or clogged. Read through the link thoroughly and let me know if you have questions. I hope this helps you.
Jan 09, 2009 | Kenmore 46462 Front Load Washer
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
ActionScript
If you are making desktop application u need 3rd party flash software like mdm zinc or flashjester jugglor. it provides easy way to write on files. If you are developing web you need to use either php / asp which ever u know. If you know nothing better is doing in php. its easy and powerful. See below for sample php code. to send from flash you have to use sendToURL(request); in AS 3.0
$fileName = $_POST["filename"];
$xmlContents = $_POST["xmlcontents"];
$lastBackslashPos = strpos ($xmlContents, “\\”);
while($lastBackslashPos >0){
$xmlContents = substr($xmlContents,0,$lastBackslashPos)
.substr($xmlContents,$lastBackslashPos+1,strlen($xmlContents));
$fh = fopen($fileName, “w”);
fwrite($fh, $xmlContents);
fclose($fh);
Mar 06, 2008 | Virtual Training Company Macromedia Flash...
Whirlpool duet model GHW9150PW3
I cleaned my drain pump fiter (F02 ). When I put everything back together and tried a cycle, there is no water flow resulting in FH. I did not touch the water supply. Help!
Aug 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
189 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
