Question about Makita 1/2" Corded Impact Wrench
I'm re wiring my makita impact wrench and need to know how to put the wires back in the correct position?
  • 3,600 Answers
Black wire on left green to base ground white to left side. on the cord end gree on round peg black on large sdade and white on small spade, but since it's a ac it wont matter with the black and white wire.
Posted on Aug 06, 2009
What is causing my 3/4" Makita electric impact wrench to overheat and slow down
remove the back cover and use some lube that is safe for electric handtools
Jun 19, 2014 | Makita Impact Wrenches 3/4" Impact Wrench...
My 18v lithum makita drill is starting to cut in and out
If impact makes a difference in how it runs, you have a bad contact somewhere. It could be where the battery connects to the switch in the handle, it could be the switch, or it could be one or both wires from the switch to the motor. It could be in the motor but it's unlikely as the brushless motors have very little to go wrong in them but they are manmade machines so it's a possibility. Makitas have a three year warranty on them and the brushless tools are a new line so it may be repairable by a service center for free.
Jun 26, 2012 | Makita 18v LXT Li-Ion Cordless 3-Speed...
The wrench is making a rattling when operated and if you put slight pressure on the shaft the rattling goes. If you could help it would be a great help thank Kev
pos 14 pos 15 and pos 20 control it and replace if you see worn parts all together but if it is still making noise and it has its working hours on it replace also pos 26 . (control also the ballbearings on tolerance and its flexible
Makita 6906 Impact Wrench Parts
Sep 06, 2011 | Makita 6906 9 Amp 34Inch Impact Wrench
Hammer on Makita model 6905H corded impact wrench 1/2 size broke.
go to web site there is a parts list for your model and order the part
May 01, 2010 | Makita 1/2" Corded Impact Wrench
89 honda accord lx 2.0 will spin but will not start. getting fire and getting fuel.i have checked all the fueses and they are good.could it be anything with the computer ?
Pull the plugs and see what they look like, and look for gas soaked, or oil soaked, carbon etc & let us know what you see.
Jul 31, 2009 | 1994 Honda Accord
Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Dec 31, 2008 | Makita 12V Cordless Impact Driver -...
Makita  1/2" Corded Impact Wrench Logo
123 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
