C-4 Kyocera mita 1620 with error code c-4, tried to reset it but still appear again. please help.
  • alfredborg May 11, 2010
    you should have more than just c4, is it c4000?
    Sniper:
  • 66 Answers
The C-4 series errors point to a problem with the polygon motor in the laser unit (LSU)
Generally speaking it is not serviceable.
Yuo will have to contact your nearest service agent
Posted on Jul 09, 2009
Error C-6 need code
replace fuser unit then 1087 1087 163 start
Nov 25, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
Hello how do I fix A-4200 problem on my copier Kyocera KM-1620?
C4200 CODE IS FOR A LASER UNIT PROBLEM, IF IT WONT
RESET BY TURNING IT OFF AND ON THE LASER UNIT NEEDS
TO BE REPLACED. EXPENSIVE PART FOR A COPIER THAT OLD.
May 21, 2015 | Kyocera Mita KM-1620 Toner Black...
What make the buttons of my Kyocera Mita KM 1620 stop working
the buttons stop working because the internal pressing are crash and you should replace it or join it by welding. but first of all you may blow the panel it could be some dust.
Sep 18, 2014 | Kyocera Mita KM1620 Black Toner Cartridge...
When i try to photocopy it always shows c-6 400
try entering 1087 1087 then 163 then 01 to return to normal copy mode. This code can come up when machine loses power while turned on. this will reset the fuser which is probably causing the code.
Jul 16, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
Km2035 error J00 kyocera mita
J00 is an unidentified jam. Means that a paper jammed in the machine and the user switched the machine off and then on again. So the machine lost the ability to inform the user where the jam is. As a result the user has to find out where the jammed paper or piece of paper is.
ALL KYOCERA MITA 1620 ERROR CODES
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Kyocera-Mita&model=KM1620
May 21, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
Kyocera mita 1620 failuire to work due to error message C2000
Drive motor problem
LOCK ALM signal remains high for 1 s, 1
s after the drive motor has turned on.
Poor contact in the
main motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable.
Defective drive
motor rotation control
circuit.
Replace the drive motor.
Defective drive
transmission system.
Check if the rollers and gears rotate
smoothly. If not, grease the bushings and
gears. Check for broken gears and replace if
any.
Kyocera Mita KM 1505 copier machine
Hello Sir,
I would like to ask you that I have a kyocera mita copier KM1505 and displays the code error like C610,So try to help me in order to resolve or fixe that problem.
Thanks
Pascal NIYONSENGA
Rwanda-KIGALI
Apr 03, 2008 | Office Equipment & Supplies
165 people viewed this question
jasbo
jasbo
