Question about Sharp AR-153E Copier
H4 code flashing. no light on the start key - Sharp AR-153E Copier
Fuser warm up error.....could be a fuse, Lamp, or thermostat. The code can only be reset via a service mode, after the problem is fixed by a tech.
Posted on Mar 02, 2009
A problemes h4-00
H4 00 - Heat roller low temperature detection - Fuser UNIT
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key CLEAR key (c) Interrupt key
Main code [START] key Sub code [START] key
Main code = 14
Sub code = 00
Apr 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
Tip
Sharp AL2020 AL2040 AL2060 AL2080 H4 H-4 code reset procedure
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:<br /> Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys) <br />Press "C" then the "Auto" key (exposure mode) then the "C" key then the "Auto" key again.<br />So in other words C, Auto, C, Auto<br />If done correctly the display should go blank.<br />Then key in 14 as if you were going to make 14 copies.<br />Now press the "print" button<br />The machine should automatically shut down and restart with the H4 code being gone.<br /> If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced. <br /> Works on Sharp AL series 2020 2040 2060 and 2080<br /> Good Luck and Thank You for using Fixya.<br />
on Dec 22, 2010 | Office Equipment & Supplies
Our copier is an AR-208D & it has a error code of H4-00 displayed. Can we fix it?
Press "#" then the " * " (star) key then the "Clear" key then the " * " key again.
So in other words #, star, C, Star
WheatlandServices
Dec 22, 2010 | Sharp AR208D Copier
H4 READING
H4 flashing mean fuser unite fault.Fix it # interrupt C interrupt 14 press start key machine on/ off.If it are not fix change thermostat or Heater lamp.
Dec 14, 2009 | Sharp AR-5320 Black and White Copier
My copier ( xerox xc1040 ) hit a power surge . It
i speak a littlebeat english.
H4
00
Low Temp
you cant erease this code
in panel control
press (clear ) (exposure select key) (clear) (exposure select key) (14) & (start key)
14: Resets H3, H4,
Feb 28, 2009 | Xerox Office Equipment & Supplies
H4-00
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and rarely the temp sensor.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Feb 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Dec 17, 2008 | Sharp SF 2020 Copier
Error code: H 4 flashes.. Nothing works
H4 PRESS START KEY THERE WILL BI A SUB CODE LIKE 00.THAT IS HEATER UNIT TEMPERATURE PROBLEM.RESET IT BY THIS PROCEDURE.
PRESS CLEAR KEY,AUTO PHOTO MODE KEY,CLEAR ,AUTO PHOTO ,
COPIER DISPLAY DEAD 14 START KEY.
PROBLEM REMOVES
BY MIAN JEE
Oct 23, 2008 | Sharp Office Equipment & Supplies
Sharp ar-5316
I am getting a problem code H4 for sharp copier when i start the machine. what is the problem. is ther any solution for the problem of the said model.
Aug 28, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-153E Copier Logo
93 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
