Question about Nintendo DS Lite Console
Can't unlock level17 Kim Possible global Gemini - help have completed mission 16, but 17 still locked
Where can i find a printable page to print all the controls and functions on lock on moder air combat please help
Scroll Lock Key nearest air target Alt + Scroll Lock Key center-of-view air target Shift + Insert Key next air target Shift + Home Key previous air target Shift + Scroll Lock Key nearest ground target Ctrl + Num Lock Key center-of-view surface target Shift + End Key next surface target Shift + Delete Key previous surface target
MISSION EDITOR Ctrl + N Key create a new mission Ctrl + O Key open an existing mission Ctrl + S Key save the active mission to disk Ctrl + Shift + S Key save the mission under another name Esc Key delete the current selection on the map Delete Key delete the current selection on the map Ctrl + Shift + C Key assign the active mission to a class and protect it with a password Ctrl + Shift + D Key declassify the active mission Ctrl + H Key hide or show specific objects on the map Ctrl + 1 Key return the map to the default magnification level around the crimean peninsula Ctrl + + Key magnify the map by a factor of 2 Ctrl + - Key scale the map down by a factor of 2 Ctrl + O Key take the view down to a very close level Ctrl + V Key magnify the map to a regional view centered on the selected object Ctrl + B Key view and edit the mission briefing Ctrl + D Key view a debriefing when a saved mission is loaded Ctrl + F Key start the current mission Ctrl + N Key begin a network multiplayer session Ctrl + M Key chat with other players during a multiplayer session Ctrl + R Key start the mission and record a video sequence Ctrl + P Key play back the last recorded video sequence Ctrl + V Key start the video sequence and enable its editing Ctrl + Shift + F Key specify failures that may happen to your aircraft Ctrl + Shift + W Key specify meteorological conditions Ctrl + Shift + E Key open encyclopedia Ctrl + Shift + O Key open options screen F1 Key help F2 Key keyboard command list
Feb 27, 2011 | Video Game Consoles & Games
Codes for unlocking smoke in mk shaolin monks ps2
here is your code for smoke
Go To A Door After The Thin River And Next To The Grapple Living Tree. This Door Is Guarded By The Living Clay Statues. First, You Must Destroy The Soldiers Shield And Then Throw Them Into The Sealed Tomb Door. Go Through The Opening And Follow A Path. This Will Lead You To Smoke, Who Will Issue Five Missions That You Have To Complete. If You Have Completed The Missions He Has Given You, Go Back To Him And He Will Give You Your Next Set Of Missions
Jun 08, 2009 | Sony PlayStation 2 (PS2) Console
How do I enter cheat codes for call of duty worl at war on playstation 3
Text excerpt found at: http://cheats.ign.com/ob2/068/902/902587.html Cheat: Cheat List Cheats are unlocked not by inserting passwords, but by acquiring the thirty Intel Pieces strewn throughout the game.
The more of them you collect, the more cheats you can access. On the left are the number of Intel Pieces collected, and on the right are the cheats that are unlocked, with an explanation of what each does.
  • 2 - "CoD Noir" Play the game in black and white.
  • 4 - "Photo-Negative" Game colors become inverted.
  • 6 - "Super Contrast" Game's contrast increases.
  • 8 - "Ragtime Warfare" The game feels like an old silent movie.
  • 10 - "Cluster Bombs" One frag grenade thrown equals five in explosion.
  • 15 - "A Bad Year" Enemies explode into tires when shot.
  • 20 - "Slow-Mo Ability" Game plays at 40% normal speed.
  • 30 - "Infinite Ammo" Just what it says.
Unlockable: Arcade Mode To unlock Arcade Mode, beat the game once through on any difficulty level. Arcade Mode itself is split into two options - Full Challenge or Level Challenge - that add extra replayability to the game.
Unlockable: Prestige Mode To unlock Prestige Mode, which is a multiplayer-only mode, you must reach experience level fifty-five. Instead of capping out at level fifty-five, which is the highest level, Prestige Mode allows you to start again from level one. This can be done a total of ten times, giving you ten different icons in in-game lobbies to show your extreme achievement.
Unlockable: New Mission To play an all-new mission, which is an extra mission after the main quest is completed, beat the game and view the ending credits thereafter. After they've run their course, you will then be given the opportunity to play one last single player mission before all is said and done.
Unlockable: Golden Weapons To unlock the following "Golden" weapons, fulfill the requirement listed.
  • AK-47 - Complete all Assault Rifle challenges
  • Desert Eagle - Attain Level 55
  • Dragonuv - Complete all Sniper Rifle challenges
  • M1014 - Complete all Shotgun challenges
  • M60 - Complete all LMG challenges
  • Mini-Uzi - Complete all SMG challenges
Unlockable: Multiplayer Weapons To unlock the following weapons in multiplayer mode, reach the numbered rank listed.
  • Assault Rifle (G3) - Rank 25
  • Assault Rifle (G36C) - Rank 37
  • Assault Rifle (M14) - Rank 46
  • Assault Rifle (M4) - Rank 10
  • Assault Rifle (MP44) - Rank 52
  • LMG (M60E4) - Rank 19
  • Pistol (Desert Eagle) - Rank 43
  • Pistol (Golden Desert Eagle) - Rank 55
  • Pistol (M1911) - Rank 16
  • Shotgun (M1014) - Rank 31
  • SMG (AK-74U) - Rank 28
  • SMG (Mini Uzi) - Rank 13
  • SMG (P90) - Rank 40
  • Sniper Rifle (Barret) - Rank 49
  • Sniper Rifle (Dragunov) - Rank 22
  • Sniper Rifle (M40) - Rank 04
  • Sniper Rifle (R700) - Rank 34
Hint: Intel Pieces Below is the level distribution list for Intel Pieces, which are enemy laptops full of information strewn throughout the game. There are thirty of them total. The left column is the level in question, while the right column is how many Intel Pieces can be found on that level. Levels with no Intel Pieces are excluded completely.
  • Level 2 - 2
  • Level 4 - 2
  • Level 5 - 3
  • Level 6 - 2
  • Level 7 - 2
  • Level 9 - 3
  • Level 10 - 2
  • Level 12 - 2
  • Level 13 - 3
  • Level 14 - 2
  • Level 16 - 2
  • Level 17 - 1
  • Level 18 - 2
  • Level 19 - 2
If the information was helpful to you, please give me a rating.
Thanks.
OpenSource13
Apr 18, 2009 | Sony PlayStation® 3 (60 GB) Console
I have a game called pursuit force and i know a load of cheats for it but i don't know how how to type them in. please help me.
Hi yousef_hussa,
Try these>
Enter the following codes at the Cheats Screen to unlock the corresponding effect
Get Invincibility:
Invincibility
Half Health:
Iron Man
No Civilian Traffic:
Open Road
Always Full Justice:
Law Lord
Double Negative Justice Loss:
Reoffender
Can't get Thrown out of Vehicles:
Sticky Feet
Make Water Choppy:
Wild Water
Double Wheel Size:
Big Wheels
Get Double Damage:
Double Damage
Move Faster:
Speed
Police Shoot Blue Lasers:
Laser Law
Unlock Vehicles for Time Trial.
Complete the following levels in the Capelli missions to unlock the corresponding vehicles.
Unlock JME Marlin:
Get an A on Cold Contract
Unlock KMT Seareaver:
Unlock Hampton Monte Christo:
Get an A on Rat Race
Unlock Hampton Avenger:
Unlock JME Otter IV:
Get an A on Witness Protection
Unlock Zephyr ATS Law Enforcer:
Get an A rank on Don the run
Unlock Deflective Armour:
Beat 'The Big Game' mission under the Killer 66 Gang to unlock 'Major' rank to be able to unlock Deflective Armour Happy Gaming :)
Apr 03, 2009 | Sony PlayStation Portable (PSP) Console
Problem in using cheat codes for playstation 2
Level Select Insert this code as name for access at all levels
Code Effect PAQUIRRIN Level Select
Passwords Also, for a bonus mission, collect all of the brown bonus books during the course of a mission to complete the photograph at the end and unlock a bonus mission.
Password Effect PLKUM Hard 1 PAEN8 Hard 10 JE5SH Hard 2 DFY3B Hard 3 K9D3H Hard 4 NMWQ9 Hard 5 16G3L Hard 6 WL3CZ Hard 7 LPQ6T Hard 8 SRCM8 Hard 9 XHGDR Normal 1 9TT5W Normal 10 WKUC4 Normal 2 YSM51 Normal 3 B7D8F Normal 4 3GHSL Normal 5 AZLM1 Normal 6 JAHSG Normal 7 UN63A Normal 8 VAZ2P Normal 9 PVTSL Very Hard 1 1LPQD Very Hard 10 SKDJF Very Hard 2 3DYNG Very Hard 3 9BG3S Very Hard 4 KJWJK Very Hard 5 E2J7H Very Hard 6 ZX78Y Very Hard 7 TRIB4 Very Hard 8 TRD78 Very Hard 9
Sep 27, 2008 | Sony PlayStation 2 (PS2) Console
Cheats for ps2 game gun
Sorry but the game gun dose not have any cheats but i can give you some unlockables and hints.
Unlockable: Reed's armored horse and Macgruder's cannon shotgun Finish story mode and all side missions for 100% completion. Then go to Macgruder mine to pick up your rewards.
Unlockable: 69 Ferguson Rifle Beat Hollister.
Unlockable: Apache Shirt Finish the Hunting Missions.
Unlockable: Dual Peacemakers Beat Hoodoo Brown.
Unlockable: Silver Spurs Finish all Pony Express Missions.
Unlockable: Cavalry Sword Beat Reed. Hint: A Hole In The Wall If you take a barrel of TNT from the Badlands mine and put it on the north end of the old abandoned house's chimney. The explosion will open up a hole in the ground with unlimited ammunition.
To get there, get out of Dodge City. Make your way to the Badlands (use your map for directions) and head into the field that has several horses and buffalo. The house and the mine with the TNT will be right next to you.
Hint: A Hole In The Wall 2 In Dodge City go over the lower part of the bridge and follow the path on the other side to the beach cave. Inside is some ammo, money, and life pick-up which often respawn when you leave and revisit the area.
Hint: Hunting Game If you happen to miss a mark when hunting game, you can always depart for other areas and force the game to respawn the target upon your return. Try not to miss the next time around.
Hint: Quarry Respawn If you scared off the quarry in the Hunt side-missions, just remember where it was and go to the nearest trader. After you talk to him and return to where the animal disappeared, it will be there again.
Hint - Enough Talk, Let's Drink. Free Whiskey Go to the bridge over at Dodge and go to the bottom by the river. Follow the river (leftwards) until you come to a little cavern. Inside are several whiskey bottles that respawn when you recycle the map.
Aug 09, 2008 | Sony PlayStation 2 (PS2) Console
MARIO N SONIC OLYMPIC GAMES CHEAT
Emblems Unlockable How to Unlock Amy Emblem Complete Mission mode with Amy Aquatics Champs Emblem Gold Medals in All Aqautics Events Blaze Emblem Complete Mission mode with Blaze Bouncing Emblem Perfect 10 on Trampoline Bowser Emblem Complete Mission mode with Bowser Sonic Emblem Complete Mission mode with Sonic. Shadow Emblem Complete Mission mode with Shadow. Knuckles Emblem Complete Mission mode with Knuckles. Luigi Emblem Complete Mission mode with Luigi. Waluigi Emblem Complete Mission mode with Waluigi. Mario Emblem Complete Mission mode with Mario. Wario Emblem Complete Mission mode with Wario Vector Emblem Complete Mission mode with Vector Yoshi Emblem Complete Mission mode with Yoshi Tails Emblem Finish mission mode with Tails Olympic Record Emblem Achieve an Olympic Record the very first time you compete in an event World Record Emblem Achieve a World Record the very first time you compete in an event Network Emblem Connect to the Nintendo WiFi Connection Rocket Emblem Peform a successful starting dash in a track event Penalty Emblem Commit a foul in an event Peach Emblem Complete Mission mode with Peach Daisy Emblem Complete Mission mode with Daisy Field Emblem Received after earning gold medals in all field events. Aquatics Emblem Received after earning gold medals in all aquatics events. Gymnastics Emblem Received after earning gold medals in all gymnastics events. Dream Emblem Received after earning gold medals in all dream events. Fencing Emblem Received after winning fencing match without losing any point. Archery Emblem Received after scoreing 120 points in archery event. Shooting Emblem Received after scoreing 40 points in shooting event Full Play Emblem Received for playing all events. Table Tennis Emblem Received for winning 5-0 in Table Tennis. Gallery Owner Emblem Unlock the entire gallery. Collaboration Emblem Play at least one event with all characters Crowns Unlockable How to Unlock Mario Crown Get all gold and 1st medals using "Mario" Daisy Crown Get all gold and 1st medals using "Daisy" Luigi Crown Get all gold and 1st medals using "Luigi" Peach Crown Get all gold and 1st medals using "Peach" Bowser Crown Get all gold and 1st medals using "Bowser" Vector Crown Get all gold and 1st medals using "Vector" Sonic Crown Get all gold and 1st medals using "Sonic" Shadow Crown Get all gold and 1st medals using "Shadow" Amy Crown Get all gold and 1st medals using "Amy" Blaze Crown Get all gold and 1st medals using "Blaze" Knuckles Crown Get all gold and 1st medals using "Knuckles" Waluigi Crown Get all gold and 1st medals using "Waluigi" Wario Crown Get all gold and 1st medals using "Wario" Dr. Eggman Crown Get all gold and 1st medals using "Dr. Eggman" Tails Crown Get all gold and 1st medals using "Tails" Yoshi Crown Get all gold and 1st medals using "Yoshi" Complete Crown Get all gold and 1st medals using every characters. Unlock Unlock Mario and Sonic Tunes Complete all 5 of the levels of the minigames found in any of the 5 doors in the Gallery. Complete all minigames and all their levels in each door to unlock all of the music available for the Gallery's Jukebox. Unlockable How to Unlock One Mario and one Sonic music track. Complete each of the 5 levels of minigames in any of the 5 doors found in the Gallery.
say thanks
Jun 07, 2008 | Nintendo DS Console
Complete
Here are some cheat codes:
Unlockable: Autobots & Decepticons Each and every Autobot and Decepticon can be unlocked and used in any mission once the game is beaten.
Cheat: Unlimited Health For unlimited health, pause the game during gameplay and insert the following password: Square, Triangle, Left Trigger, Right Trigger, Up, Down, Left, Right.
This link might be helpful.
Nov 19, 2007 | Sony PlayStation Portable (PSP) Console
GTA 3 in ps2 slimline
put in the dodo flying car cheat(rightr2or1L2downL1R1)
Nov 14, 2007 | Sony PlayStation 2 Slimline Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Troy Gorman
Troy Gorman
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
